Deutz-Allis 5220
   / Deutz-Allis 5220 #1
msb1766
Platinum Member
Guilderland, New York
SC2450 Cub Cadet/Yanmar
I am looking at a Deutz-Allis tractor model #5220 , It's 26HP, front end loader, backhoe, and brushog, 4WD, Ag tires 800 hours, the backhoe is a APRS 70. he is asking $13,000.
Is this a good price?
I know nothing about Deutz-Allis tractors so fill me in as much as you can.
What years were they made?
   / Deutz-Allis 5220 #2
Age no older than 1985 as I have an 1984 5020 which I purchased new. I would really think about how much and how hard you are going to use the loader and hoe on this unit, they are what I consider "early" in the compact tractor history, and hadnt really evolved into the machines marketed today, while the 5020 has been a very good machine (yes I still have it) there are several shortfalls in the design of that period for tlb duty in my opinion, an aluminum bellhousing, not the heaviest front axle (atleast for loader work), and most lacked power steer. If the loader and the backhoe are not Full frame designs I would walk away if the machine is gonna see alot of tlb work.
   / Deutz-Allis 5220
How can I tell if the loader and backhoe are Full Frame?
I know the backhoe is hooked to the 3-point hitch.
   / Deutz-Allis 5220 #4
The factory loader frame for the 5020 ran from the front of the machine hooked in the middle and also attached to the rear axle. But check the bellhousing to see if it was still aluminum on the 5220 as they may have changed it? My dealer told me not to put a half frame loader on the 5020 due to the aluminum bellhousing.
   / Deutz-Allis 5220 #5
The 5220 does not have an aluminum bell it is iron and is well suited for loader work. I own a 5230 which is the same tractor besides engine specs.(5220=26hp and 5230=31hp). I also have an ARPS backhoe that is a three point hitch hook up and it has given me years of trouble free service. Parts availability is still OK through AGCO but some parts are no longer available. The price is a bit high for an older machine. For the right deal they are solid tractors. I got mine with a front mount 60" two stage Schulte snow blower, I may be selling mine soon to buy a larger machine. It has been a very reliable machine.
   / Deutz-Allis 5220 #6
Hey I'm new to the forum. I bought a deutz-allis 5230 about a year ago. Really nice tractor. Changed all the fluids and filters when i first got it. My question is I'm having a hard time finding a spin-on hydraulic filter. Was wondering if you have a cross reference number for the filter. Agco part number is 7210255. Checked a few of the local auto parts store, but no luck. Bought a service manual from jensales, but it wasn't much help for changing the hydraulic filters and fluid. Any help will be appreciated.
   / Deutz-Allis 5220 #7
The good 'ole Fram PH8A that fits most old Ford V8's threads right up! They are cheap and plentiful!
   / Deutz-Allis 5220 #8
I AM NEW TO THE SITE AS WELL AND AM LOOKING FOR THE FRONT AXLE HUB THAT MOUNTS TO THE FRAME. THE SHOULDER MOUNT FOR THE AXLE HAS BROKEN OFF AT THE BOLT HOLES. CAN ANYONE MIGHT KNOW OF A SOURCE OR IS IT POSSIBLE TO WELD THE IRON FRONT END BACK TO THE FRAME AND REINFORCE IT WITH SOME TYPE OF U-BOLT CLAMPS TO HOLD IT IN PLACE. THANKS IN ADVANCE FOR YOU HELP. STAN
Platform Scale (A42745)
Platform Scale...
2013 FORD E350 BOX TRUCK (A43004)
2013 FORD E350 BOX...
SKYTRACK 10054 (A45046)
SKYTRACK 10054...
Lot of 3 Unused Commercial Electric PC500 500Watt Portable Flood Lights (A44571)
Lot of 3 Unused...
2007 MACK CHN613 (A45333)
2007 MACK CHN613...
Mitsubishi FG35 Forklift  8,000lb Lift Capacity, LP Gas (A44789)
Mitsubishi FG35...
