Deutz Agroplus 87
   / Deutz Agroplus 87 #1
HDSelf
TX
Deutz Fahr Agroplus 87, Farmtrac 550 DTC
I have had this tractor for about 5 years. I have had to replace the speed sensor three times at $160.00, has anyone else that owns a 87, had this problem? If you have had this problem, have you had a fix for it? Seems to go out just when you need the tractor, like baling hay.
   / Deutz Agroplus 87 #2
HDSelf - Do you have any dealer support on the issue? I looked pretty closely at the DF vineyard tractors last year which were also known to have the speed sensor issue when I talked to owners in the east. All said they got good support from Paige Equipment in Williamson NY. When I talked to Paige about the issue they seemed to have a good handle on the problem and a possible fix beyond part replacement. You might give them a call and talk to the owner John.
   / Deutz Agroplus 87
John, No, that is the problem, all the Deutz dealers within 200 miles of me closed their business. I have talked to a couple dealers by phone and they know of the problems, but don't really know the fix. I did learn today that Deutz has what they call a E-Box, that fixes some problems with the sensors, but don't know if it fixes mine. Already spent to much on sensors now. I like the tractor, but hate the problems, with no local dealer for help. Do you happen to have a phone number for Paige Equipment, I will give them a call and see what they say. Thanks John for responding to my post. I don't know anything about the DF vineyard tractor, so I am no help there. Thanks again.
H.D. Self
   / Deutz Agroplus 87 #4
search dr deutz he should be able to help
   / Deutz Agroplus 87
Thanks whis.
   / Deutz Agroplus 87
Does anyone know what the model number or name of the fault code reader for the Deutz Agroplus is? I need to try to locate one so I can reset my fault codes. Thanks
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2025 JMR 36in Bucket Skid Steer Attachment (A51691)
2025 JMR 36in...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2025 K0520 UNUSED (5) Welded Wire Mesh Roll (A53117)
2025 K0520 UNUSED...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A51247)
UNUSED CFG...
