You need to get a look at the Kubota parts book for the valves you have, each valve manufacturer is specific as to what parts are needed.
Here's a link to the Prince parts manual for their stack valves.
http://www.princehyd.com/Portals/0/products/valves/Series20Manual.pdf
The part pertaining to the spool detent option is on pages 9, 10 and 11. This particular valve offers several different options depending on what you need the valve to do. Some have 3 detented positions, some are spring centered with detents on the two ends, some are two position with one detented, etc. In general, the detent parts are in the end cap on the end of the spool opposite the lever.
Your dealer is the best bet for what's available specific to your tractor, with any luck they'll have a mechanic that can listen to you tell him what you want it to do, then order the right parts and install them.
If you have a front end loader, the lift cylinder float position is an example of a spring centered detented spool valve, it holds the valve in that position unless you move the lever to pop it out.
With any luck, someone else will have more specific experience with the Kubota stack valves than I do, I added an aftermarket valve to mine.
Sean
