destroyed spindle
   / destroyed spindle #1
6thgpSF
N.E. Kansas
YM1610d bobcat 863 Gh 928d
Last week mowing with my 928d Grasshopper I noticed it was making a wierd noise where the spindles are located.I popped the cover and found a spindle that was totally gutted as well as the sheave.I grease my spindles after every mow which is 3acres maybe every 2 weeks.I read that too much grease is just as bad as not enough grease.So how much and how often should this be done?I've got a new spindle ,should I grease it until I see grease and how often?Don't have a manuel for the deck so hoping some one can help me with this.thanks in advance...russ
   / destroyed spindle #2
Greasing sealed bearings that weren't designed to be greased is one of my pet peeves. I know that folks with a brand new grease gun, especially those with a new battery operated one, will get all pumped up:laughing:
   / destroyed spindle #3
Greasing sealed bearings that weren't meant to be greased? If thats the case, there shouldn't be a grease zerk. The only problem I've heard of by over greasing is maybe blowing out the seal. For some reason, I've always gone by the three pump rule. Nobody taught me this, but three pumps of grease usually seems like the right amount for a bearing. For pins on a end loader, I usually go until I see a little old grease forced out.
   / destroyed spindle #5
I have a Kubota BX, and I think it had a sticker on the loader that says every 10 hours.
   / destroyed spindle #6
Do you wash your deck with the water hose? When it is hot?
   / destroyed spindle
I never wash the deck,I scrape it with a plastic putty knife.Guess I should have been more specific,the spindles on my mower have zirks.Could a belt not tensioned right have done this?I put new belts[2] on it this spring and they were really tight,I had to bring the adjusters out all the way to get them on,do you think this could have destroyed this spindle?..russ
   / destroyed spindle #8
Lots of info missing. How many hours on the spindles? Have you owned the mower since new? Using the right type of grease? If mixing greases are the thickening agents compatible? And yes, IMO you are over greasing the spindles.
Dennis
   / destroyed spindle #9
Just my opinion here, but I don't think over greasing caused your failure, unless you were putting 10 pumps of grease in every time. I had a cheaper mower at one time, and broke some spindles on it, and I always thought it was from hitting things, like stumps, rocks etc. Sometimes its just a defective part.
   / destroyed spindle #10
Dennis
You hit the nail on the head. WAY too much info missing. Bearings do NOT last forever, even when greased regularly. For all we know, this machine has 5000 hours on them origional spindle bearings:confused2:
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A52377)
2012 International...
1992 BOBCAT 743 SKID STEER (A52705)
1992 BOBCAT 743...
2007 International 4400 2,000 Gallon Water Truck (A52377)
2007 International...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
