Designs for 3 Pt. Booms
   / Designs for 3 Pt. Booms #1
gannman
i am building a 3 pt boom sprayer and need some help with my design for the booms. i plan on making them span 30 feet. Do i need some way to take out the shock or will solid booms with break away hinges work?
audie
   / Designs for 3 Pt. Booms #2
Depends on what you build them out of. 15' is pretty long and it has to support hose, fittings, nozzels and the breakaway hinges. It has to be strong enough to absorb shock loads and enough force to the point that the breakaway hinges give if you hang up on something. You might want to look into a truss structure or something with a cantelever and top strain wire or kingpost and wire. This would allow you to build lighter for a given strength and lessen the shock load forces as things bounce around.
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
Ford Stakebody Truck (A52377)
Ford Stakebody...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
