Grading Delta Mower Blade Sharpener with Jig
   / Delta Mower Blade Sharpener with Jig #4
</font><font color="blue" class="small">( Someone over in the Attachments forum recently posted this Delta Mower Blade Sharpener with Jig. )</font>
That might have been me. FYI, the large red stone which is used for wet grinding a very fine edge on a knife (generic term - such as a tool steel knife on a wood chipper) or planer blade - and is not suitable for sharpening mower blades. It is way too fine (1000 grit) and is way too slow (400 rpm) You would be there an eternity if you needed to remove any amount of metal.
The white stone on the left side of the machine is totally fine for sharpening mower baldes however - it runs at 3450 rpm and is 120 grit. There is removable tool holder post that can be inserted on either wheel that the tool holder (slide) mounts to. The tool holder itself probably isn't suitable for sharpening most mower blades (you'd have mounting issues getting your blade on it) - you need to fab your own blade jig that then could be mounted in the tool holder (or not). You grind on the circular surface of the white stone - not across it (left to right, right to left) - but rather front to back, back to front. See figures 34, 35, & 36 in the PDF instruction manual available ofn Delta's website.
Hope this helps.
Rats, this is disappointing. Still though, for those purists who sharpen with a hand file, when that rotten enemy, old age, brings on the arthritis, this may yet be an alternative. If $ were no concern, maybe one could use the stone on the left, or go freehand with an angle grinder, for the initial passes, then use the flat stone on the right for a final edge??
BTW A Google search showed prices at other retailers to range from $165-$180.
   / Delta Mower Blade Sharpener with Jig #6
The flat stone on the left is sufficient for putting a final edge on a blade - the wet grind stone is not really necessary. The trick is to have some way to hold the blade so that it maintains the angle as the blade is drawn over the grinding wheel. The post and tool holder will fit on either side/stone, and while the tool holder itself may not be suitable for lawnmower blades it can be used as part of a jig/holder for lawnmower blades.
There may be other, coarser grit stones available for wet grind side - dunno haven't explored that possibility myself.
Here's another cheaper alternative that could be adapted for sharpening lawnmower blades:
Harbor Freight version
And another similarly priced unit that's a little different:
Tool & Carbide Grinder
If you are pretty good with a right angle grinder (hand held) you could probably put a fairly decent edge on a blade - I've managed to finally get to a point now where I can. /forums/images/graemlins/grin.gif
John Deere Bale Spear (A50515)
John Deere Bale...
2014 Gillig 31+56 Low Floor Bus (A50323)
2014 Gillig 31+56...
2008 Ford F-150 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
(1) 24' CORRAL PANELS W/ (1) 12' GATE (A51243)
(1) 24' CORRAL...
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2016 JLG ECOLIFT...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
