Delo 400LE vs Tractor Supply House Brand
   / Delo 400LE vs Tractor Supply House Brand #1
UncleBuck01
NY
Mahindra 4110
Asked wife to stop at Tractor Supply when she went shopping this past weekend, asked her to p/u 3gals. of DELO 400LE CJ/4 diesel engine oil which is on sale for $10 a gal. She came back with Traveller all fleet diesel engine oil 15W-40 CI/4 which was on clearance $4.99 a gal. What Would You Do, use it for spring oil change in my tractor, a Mahindra 2002 4110 with 800+ hrs or go get the DELO oil which is still on sale.
Do something special for your wife... It looks like she just saved you 5 $ a gallon = $15... KennyV
I did, I married her 29 years ago,
just kidding :D , So I'm guessing you would use it for the spring maintenance
   / Delo 400LE vs Tractor Supply House Brand #4
Sure... They are both good quality 15W40 diesel rated motor oils... That is what you have been using.
Myself, I use synthetic but I don't think you can go wrong using good multi-viscosity non-synthetics. KennyV
   / Delo 400LE vs Tractor Supply House Brand #5
BTW...
There are a lot of oil folks that will tell you to get all the CI-4 oil you can as it is a superior formulation to CJ-4... But do not use CI-4 in a on highway diesel with an exhaust aftertreatment device such as diesel particulate filter (DPF) or diesel oxidation catalysts.
You will not be able to find CI-4 after the existing stock is sold out. There was a big run on it here about a year ago and it disappeared quick. KennyV
BTW...
Ken
Does oil have a shelf life, at that price should I go buy whats left at the store
   / Delo 400LE vs Tractor Supply House Brand #7
That is an arguable question.. everything has a shelf life, but a lot of things have such a long life expectancy that it is not normally considered...
I would not be concerned with having several years oil supply on hand, if it were available at a good price.
That said, you and everyone else will eventually have to switch to the latest blends--- at some point. KennyV
   / Delo 400LE vs Tractor Supply House Brand #8
I sure hope it lasts a long time - I scarfed up about 40 gallons of RTS 5-40 CI-4+ last year. ;)
   / Delo 400LE vs Tractor Supply House Brand #10
I bought Rotella around 2004 in gallon jugs for $3 per gallon that was on clearance due to it being the old white bottles. I am down to my last 3 gallons and only run it in my tractor. It has the foil covers under the cap so yes it may have a shelf life but I am sure it would last for 10 years or more if in sealed containers.
Chris
1998 KENTUCKY ENCLOSED CAR HAULER (A43004)
1998 KENTUCKY...
Daewoo SL220LC III - Excavator (A42203)
Daewoo SL220LC III...
HP MANUFACTURING  500BBL WHEELED FRAC TANK (A45046)
HP MANUFACTURING...
2012 Volkswagen Tiguan SUV (A42744)
2012 Volkswagen...
2005 TRIPLE B TRAILERS UTILITY TRAILER (A45333)
2005 TRIPLE B...
2013 Kubota KX080-4 Midi Excavator (A42742)
2013 Kubota...
