DELETE A DOUBLE POST ?
   / DELETE A DOUBLE POST ? #1
Jeff Lary
Hartland Maine
Kubota L2950
How do I delete a double post I,,, did it by mistake but can not seem to get rid of it?
   / DELETE A DOUBLE POST ? #2
Request you send a PM to an administrator with link to one to be deleted.
   / DELETE A DOUBLE POST ? #3
just click on the triangle with exclamation post on left of the post you want to delete and add a note why you want to report post like delete double post.
   / DELETE A DOUBLE POST ? #4
Jeff, radioman has the right answer. But in this case, I've already found the double posting and removed one. You can also use the "Edit" button to delete one of your own posts, but there's a relatively short time span in which you can do that.
UNUSED Safety Traffic Cones (A50860)
UNUSED Safety...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2021 John Deere 9570R Articulated 4WD Tractor (A50657)
2021 John Deere...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
