Definition of Pickup - heads-up
   / Definition of Pickup - heads-up #1
DavesTractor
Elite Member
Red Bluff, CA
Changes often!
In California, a pickup is no longer a pickup if the GVWR tag is 11,500 or greater. Even if it is registered as a pickup and has the original pickup bed. This has some interesting ramifications.
CVC 471. A "pickup truck" is a motor truck with a manufacturer's gross vehicle weight rating of less than 11,500 pounds, an unladen weight of less than 8,001 pounds, and which is equipped with an open box-type bed not exceeding 9 feet in length. "Pickup truck" does not include a motor vehicle otherwise meeting the above definition, that is equipped with a bed-mounted storage compartment unit commonly called a "utility body."
My 2006 Dodge dually is rated at 12,200. So when I go by any open scales, even unloaded and with no trailer, I am breaking the law. It says "no pickups", but I am not a pickup. This has been brought to my attention by the CHP. It also means, since I occasionally tow a 20' 14K bumper pull in my business, I am subject to the California BIT (terminal inspection program), employee pull notices, drug testing, etc...just like a Peterbilt with a real trailer.
As a practical matter, the scale issue isn't enforced with any enthusiasm, but the BIT program is.
I've contacted my local government representative and he agrees the definition should be changed to a higher rating, but changing things like this is slow. I contacted Dodge and asked about a derating, and they have not been helpful. Anyone else have to deal with this? We are all legal, CDL, motor carrier permits, BIT, etc., but it seems ridiculous.
   / Definition of Pickup - heads-up #2
..with an open box-type bed
Simple solution, play by the "law" . Get a cap over your bed, and you no longer have an "open" bed. If your towing with a goose neck that could be a problem.
But close the bed and you no longer have an "open" box. ;)
The point is that I want to be defined as a pickup, not otherwise. Closing the bed wouldn't help, unless I am not following your train of thought. I do have a gooseneck, so I guess it wouldn't matter as I have to keep the bed open. Keep the ideas coming!
   / Definition of Pickup - heads-up #4
I don't suppose moving out of California would be considered a reasonable option :)
Once you are here, they don't let you leave.....:eek:
   / Definition of Pickup - heads-up #7
Oddly enough, an extreme form of the CA statute could be used to increase manufacturer fleet mileage without resorting to bizarre tax schemes and other restrictive requirements created by "lawmakers".
Make every vehicle GCWR 5001lb or more subject to CDL... after all, if you have the GCWR, the implication is that you will use it. This might keep a lot of bloated SUVs off the roads, but still allow people who need the capacity to do so without a huge additional cost burden.
   / Definition of Pickup - heads-up #8
Vote for gummint representatives who have brains?
Not to suggest my own state as an example, of course.
   / Definition of Pickup - heads-up #9
Fellow resident of "The Peoples Republic of California" here... My buddy used to live in California and had a Ford Super Duty dualie and was over the limit like yourself. The loophole in the law is closing the bed. Because of the outrageously high registration costs for the higher GVWR, he justified the cost of a lightweight tonneau cover for his bed and was able to register as a pickup. I believe that he also had to have the interior carpeted, but that may have just been something else he decided to add anyway (used carpet is free). My understanding is that a camper shell, tonneau cover or the like will suffice for the loophole, but get caught with it off "temporarily" and standby for the fines!
Just reread your gooseneck comment... Maybe an easily removable custom plywood cover with a hole cut for the gooseneck will work.
   / Definition of Pickup - heads-up #10
Dave,
It is ridiculous alright. Here is my story.
The GVW rating of F350 SRW increased in 2006 to over 10,000, which forced me to downsize to an F250. The 06 F250 has 100lb (9800)less Gvw than my 03 F350(9900). The increased GVW would have increased plate costs and triggered mandatory inspection at 6 month intervals here in Illinois.Dooh!
If I read the Fed USDOT law correctly, any single mototrized vehicle over 10,000 GVW is considered a commercial vehicle, and any single vehicle with GVW 26,000lbs requires drug screening. Also any trailer over GVW 10,000, regardless of what it is being towed with, triggers drug screening in addition to Class A CDL also.
I too have a 20' 14,000 BVW bumper pull bobcat trailer. Only 2 of us pull it, and I am not class A CDL. We registered it at 10,000. IF I get pulled over and it becomes a problem due to the 14,000 GVW, I will fight any tickets, seeing that I can not legally pull over 10,000 because that is what it is registered for.
When the feds changed the laws in 93? it was supposed to uncomplicate things. ahh, government at its finest.
Marty
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
2015 ISUZU NPR 16FT BOX TRUCK (A52577)
2015 ISUZU NPR...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
