Definition of an easement
   / Definition of an easement #1
pdxman
Scappoose, Oregon
Kubota B6200 HST
I have real property that includes a 400' driveway inside my defined property lines. Two other properties utilize this driveway to access their own driveways. In looking back thru the legal mumble jumble of past warranty deeds, easements were granted to these properties for ingress/egress onto their properties. Don't have a problem with this. But does an easement only grant the rights to use this or does it also make the properties mutual 'owners' of this defined easement land?
   / Definition of an easement #2
Here's what I found on the web:
EASEMENTS
An easement is a non-possessory interest in land owned by someone else which entitles the owner of the interest to a limited use or enjoyment of the land and to protection from interference with its use.
Because an easement is an interest in land owned by another person, it must be transferred and used subject to laws governing real property. A land owner cannot, as a rule, have an easement over his own property. An easement holder is not entitled to the same benefits as a person who has rights of possession, such as a tenant under a lease.
The most common easements are access easements, which grant the right to cross someone else’s property on a designated road. Another type is a solar easement, which would, for example, grant the easement holder permission to come on neighboring property and trim landscaping above a certain height to prevent it from blocking solar panels.
Easements can be divided into two classes: easements appurtenants and easements in gross. “Appurtenant” means “belonging to,” and an easement appurtenant is created for the benefit of and belongs to another tract of land. In a roadway easement, for example, parcel A would grant an easement to parcel B for access to a public road. That easement would “burden” parcel A and “benefit” parcel B, regardless of who owns the property.
An easement in gross is a personal right in another person’s land. Such easements could be granted to utility companies to install and maintain telephone lines on private property.
Unless otherwise specified in the easement document or by subsequent amendment or termination, the term is perpetual. Once an easement appurtenant is granted, it runs forever with the land for the benefit of the “dominant tenement,” or the tract of land to which the easement belongs. Easements in gross also continue in perpetuity no matter how often the property changes hands. In both cases, renegotiation is necessary only if all parties agree to it.
If the easement is granted by someone other than the fee title owner, however, it’s valid only for the duration of that person’s estate in the property. For example, an easement granted by a tenant under a 10-year lease would terminate with the lease.
Easements can also be terminated when they no longer serve the purpose for which they were granted, by merger of the two tracts of land involved in the easement, by foreclosure or by an owner releasing or abandoning his interest in the easement.
The deed holder has full rights of possession and enjoyment of the property. He may grant the easement to other parties, sell the land over which the easement runs, plant shrubs and crops or erect fences, as long as it doesn’t interfere with the easement holder’s rights.
The easement holder only can use the land for a stated purpose, such as access to a road or a water line. He does not have a possessory interest in the property so he can’t restrict use or possession by others, as long as that use doesn’t interfere with his use or enjoyment of the easement. Nor can the easement be granted to a third party.
Maintenance obligations are typically outlined in the easement document. In the absence of specific provisions in access easements, Oregon Law has determined that each party shall be responsible for maintenance costs in proportion to their use of the easement.
To protect the rights of the easement holder and property owner, put any oral agreement in writing and record it in the county in which the property is located. Be specific about the terms of the easement. If you’re granting an easement for a road and don’t want logging trucks or long haulers using it, be sure to set forth this exclusion in the easement document. If you’re purchasing an easement for your own access and you expect it to be used for several parcels you’ll partition from an existing parcel, make sure the grantor of the easement agrees to this, or your development plans may suffer.
Also, be sure to include the legal descriptions of both easement and property to be benefited by it. Unlike other real property, an easement can be considered valid without a locatable legal description, but an easement “over the existing roadway” may adversely affect your property should there be a dispute over the location.
Finally, consult a real estate attorney, surveyor and/or title insurance company for help drafting the legal description and terms of the easement.
   / Definition of an easement #3
Good question. Don't know the answer. Hope you like your neighbors. Could you be liable if you maintain the driveway and they get injured on it? Sounds like lawyer time. This is one of the things that they can be very helpful with. I'd like to see the answers, if you get them.
<font color=green> MossRoad </font color=green>
   / Definition of an easement #4
When I buy property, I always use real estate agents and lawyers.
The property we just bought was being sold by owner. We hired an agent to represent us. Turns out the property had a lien against it (owner had not paid a $145,000 nursing home bill 3 years earlier) which the seller claimed not to know about (I believe her). Additionally, she had power of attorney because her father (the property owner) was declared incompetent. In order to properly record the deed, we had to submit the deed and the original POA document. I shudder to think what might have happened, not to mention the mess we would have been in down the road, had we tried to handle this on our own. Plus, the seller paid all the agent fees. /w3tcompact/icons/smile.gif
Thanks Buzkeg, very informative. Where did you find this? As far as my neighbors go, one is family, the other is crazy. All parties involved do have a joint maintenance agreement in writing and each share liabilities. The crazy one drives like the ground is going to crumble beneath her and concerns me since my kids, people on horseback, and pets can be on this driveway at any given time. Want to establish an agreement in writing deeming safe driving speeds and yielding to others to be abided by all who use driveway. Because this is a private drive, it first needs to be handled privately. Consulting a lawyer may be my next step.
   / Definition of an easement #6
pdxman,
I suggest that you get the other family member involved in this issue since they are affected by any legal action ensued. Bad enough to get a neighbor mad. But family, ack!! /w3tcompact/icons/blush.gif I would enhance your position against the offending neighbor.
Why don't you install some "speed bumps" as swales to control water drainage? /w3tcompact/icons/wink.gif
Terry
Terry, family neighbor is in complete agreement with us on this and has the same issues as us with the crazy neighbor. They helped me draft what we deem as safe driving habits. As far as speed bumps go, her driving has already created these on the gravel in the form of washboards and have no affect what-so-ever and add more danger to the mix. Will have to fix these this winter once the ground gets soft enough at mutual expense.
To build my case even further on her driving habits, our small local newspaper which prints traffic offenses published her name twice recently for speeding and failure to obey a traffic signal. On top of that, another local told me her husband was run into the ditch on the county road because she crossed over the center line. After hearing our complaints, he now regrets not reporting it.
I am certain her driving is not alchohol related. I just think she doesn't have a clue on how to drive and high insurance premiums not a factor.
   / Definition of an easement #8
pdxman,
Well, it certainly sounds like you have all of your bases covered.
Based on your description of this women, I would say she doesn't have a clue, period!! Nor does she care!!
Good luck to you!!
<font color=blue>An easement is a non-possessory interest in land owned by someone else which entitles the owner of the interest to a limited use or enjoyment of the land and to protection from interference with its use.</font color=blue>
Wait a minute.... since the easement is on your property and she is infringing on your rights of use and ownership by driving at unreasonable speeds and causing damage to the drive (limited use in the snipit above). You might just be able to take her to civil court and have her pay damages. Also, why don't you just call the local police and report her. If she is a know element where you live, the police may just want to help you with your problems.
Terry
The damages (washboard) so far do not concern me as much as her threat to anyone on any roadway. I have spoken with the county sherriffs dept and their recomendation is to first handle my issue privately. My letter defining reasonable safe driving on the driveway goes in the mail today and applies to all residents and their guests who use it. The Sherriffs dept told me once we've done that and it continues, if we observe her driving out in this manner they can be called with her license plate # and possibly stopped down the road. I can also file a complaint. It may come to this, but I first wanted to start out with a reasonable solution before going to more threatening alternative like calling the police.
<P ID="edit"><FONT SIZE=-1>Edited by pdxman on 11/08/01 02:33 PM (server time).</FONT></P>
   / Definition of an easement #10
You're good.
Appears like you have all your bases covered. Good luck to you .
Terry
3 Cameras (A51695)
3 Cameras (A51695)
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
TEST BID LOT (A50775)
2003 Paris Utility Trailer (A52377)
2003 Paris Utility...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
HYDRAULIC PTOS (A53843)
HYDRAULIC PTOS...
