Tires Defective "Titan" Tire on DK45
   / Defective "Titan" Tire on DK45 #1
kingkioti
Frewsburg, New York
Kioti DK 45
Defective \"Titan\" Tire on DK45
I finished brush hogging with my DK45 tractor on Monday. I went into the garage on Tuesday and noticed I had a flat right front tire. I figured I picked up a thorn in the tire. I took it to a local tire dealer to have it repaired. When I stopped back to pick it up, they told me that there was no repairing the ag tire because the tread had separated from the inner casing. I wish I had taken a photo of it to post on this site. They sent the tire back to the local "Titan" tire wholesaler and I replaced the tire at my expense because I was in a hurry. I am waiting to hear back from the tire dealer to find out what the wholesaler can do as far as getting me a credit towards the replacement. I have only had the tractor 11 months and it only has 56 hrs on it. I was brush-hogging a steep hill with the tractor engaged in 4WD using low-range 1st & 2nd gear, running the engine at 2500 rpm/500 pto-rpm. I brush-hogged for approx 10 hrs altogether covering 3 days. I'm extremely happy with the tractor itself. It runs like a champ and has all kinds of power for what I ask. I would buy another Kioti in a heartbeat. I talked to the tractor dealer where I purchased the tractor and they told me that if the tire wholesaler can't do anything for me then they will contact Kioti about the issue. I am more concerned about the tire being defective because of brush-hogging on a steep hill. Has anyone out there had the same problem? Any comments would be appreciated.
   / Defective "Titan" Tire on DK45 #2
Re: Defective \"Titan\" Tire on DK45
I had a problem back during the winter with a Titan R-4 on the front of a LK3054 that only had about 60 hrs on it. I noticed it was flat and I had found a slow leak in the tread. So I took it to the tire shop so they could put a patch or tube in it. When I went to pick it up they told me that it was not repairable. The inside of the tire had split from side to side and was leaking out through a pin hole in the split. They said that this is usually from a hard impact. Since no one else operates the tractor but me I know that I didn't hit anything that could have caused that to happen. At the time I needed the tractor up and running and they could not get a Titan so they matched it with another brand. The tire shop had said that if they had put a tube in it in no time the tire would have pinched the tube and pop it and there was a real good chance the tire would let go. I didn't have time to try the warranty game.
   / Defective "Titan" Tire on DK45 #3
Titan seems to be a popular front tire - my new Kubota L3130 has them as well. Thanks for the heads up, I'll keep a close watch on mine.
   / Defective "Titan" Tire on DK45 #4
I would almost be willing to bet that it is a 4 ply tire. Seems like all manufactures use 4 ply on compact tractors. If the tractor is used for very much loader work, 6 ply should be installed on the front, but they don't. When you replace them, up grade to 6 ply and that will eliminate you problems. I have been there and done that.
JerryG,
Thanks for the info on the tires. I checked mine and they
happen to be 6 Ply . I have yet to hear back from the local
Titan wholesaler to see if they are going to stand up to the
defect.
Thanks,
KingKioti
Backhoe Bucket (A50515)
Backhoe Bucket...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2014 Ford F-150...
Show Livestock Double Blower Stand and Fan Stand (A50515)
Show Livestock...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
91013 (A48082)
91013 (A48082)
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
