idahofarmboy
Hello everyone,
This is my first post, however, I have been reading your posts for the past year and the knowledge I have gained has been invaluable, THANK YOU!
This is the first time I have not been able to find an answer in previous posts. It is a little long, but this is the shortest I could make it and get the details straight.
I have a 2013 JD 3032e that just turned over 50 hours and I was doing its first oil change. Old filter spun off without problems, by hand. I put on the new filter without incident by hand(3/4 turn past gasket contact), and when I started the tractor there was a waterfall of oil all over the garage. I KNEW the gasket was in place because I am OCD about that and thought maybe it was just not on tight enough, so I twisted as tight as I could get with bare hands(no wrench) about another 1/2 turn. Filled the oil up again and after I started the same result, oil everywhere. I then took the new filter off which required a filter wrench the ENTIRE time, to the last turn, to get it off. The gasket was still in place. I also noticed no oil had made it to the center of the filter.
Tried putting the old filter on, which was now tough to get on, but then spun free the last few turns before gasket contact. Started the tractor, no oil waterfall. When taking off the original filter, it spins free for a couple turns, then I have to use a wrench to get it the rest of the way off.
I then verified it was the right filter on JD website, it was, M806419. I then cross referenced the part number and bought a K&N filter at local auto parts store. New K&N was tough to turn at first, then spins free last couple turns until gasket contact(just like original now does), spun another 3/4 turn and so far is working fine, no leaks.
It is obvious no oil was passing through the filter. I think the back flow valve was defective and did not let the oil in. I think the pressure from not having oil pass through the filter put too much stress on the filter which damaged the threads, making it hard to remove after I started the tractor the first time with the defective filter installed. I don't think I could have damaged the threads intalling because it spun free when first installed and I only used bare hands to tighten.
My questions:
1 Has anyone else had a defective oil filter from John Deere?
2 Can the threaded portion of the filter mount be replaced by itself, or does the entire mounting plate need to be removed? I think it twisted out a little when removing the defective filter, and I think that is why I have a couple clean threads at the base now which allow for easy spinning right before gasket contact.
3 If it was a defective JD filter which caused the damage, will a JD dealer pay for the repair? I am afraid every time I do an oil change I will be putting more metal filings in the oil on the engine side of the filter when passing over the damaged portion of the threads.
Thanks for your input
My questions:
