Deere LX266 engine model number
   / Deere LX266 engine model number #1
wolfden793
Lyndonville Vermont
Deere LX 266, John Deere Gator TX, Kubota B7500, Takeuchi TB016
Hi Folks!
I have a Deere LX266 lawn tractor that needs rings and the Kohler model sticker is gone, so I'm trying to find out what model engine I have so that I can order the correct parts. So far, I found that it is a CV series engine (16HP) and there were two models produced for that tractor. One is CV16 43418 and the other is CV 16 43526. The only identifying stickers on the engine are model PS26511 and a serial of 3303403733. I assume these are Deere numbers. Can anyone tell me which engine I have based on this information? This is going to be a winter project. Thanks in advance!
   / Deere LX266 engine model number #2
Have you tried looking at Deere parts website. They might tell you based on tractor serial number.
Great idea! Thanks for your reply and I'll check this out.
Jim
   / Deere LX266 engine model number #4
Hi,
Thanks for this information. The serial number of the tractor without the last three digits is MOL266BO74. I think I've got it nailed down, but welcome continued input.
Jim
   / Deere LX266 engine model number #6
A quick tip if you haven't torn it down yet, oil burning on these is more likely to be a head gasket. Though she does have a few years on her.
Hello!
Thanks very much for this information. It would be great if that's what is causing the burning. Beats a complete tear down! Engine has 561 hours and uses absolutely no oil. I use Mobil1 10W30 and change the oil every fall. Always been a great mower.
   / Deere LX266 engine model number #8
You bet. If there's no fuel dilution of the oil, I'd pull the head first.
(3) VACUUM PUMP TANKS (A50854)
(3) VACUUM PUMP...
2006 Peterbilt 379 T/A Wet Kit Sleeper Cab Truck Tractor (A49461)
2006 Peterbilt 379...
Komatsu PC138 (A50490)
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
