Loader Deere Loader Stuck Up
   / Deere Loader Stuck Up #1
turboviking
Bronze Member
deere 4610
Hello! I have a JD 4610 with factory installed rear hydraulics - and it is switched electronically with a rocker switch on the right operator's console panel. Some time back a problem started that after mowing or doing work with the rear hydraulics only, the front wouldn't re-engage. It wants to and when the switch is pressed the rear is disabled (top and tilt) but the front loader won't work. The tilt function works fine, but the raise and lower won't. I've checked wiring, and such, but now I'm stuck with the loader in the air and it won't come down. It WANTS to do something and will go up and down about an inch or two, but that is it.
Any idears? Anyone really understand this setup and what valves / solenoids etc. do what?
Thanks in advance.
Troy
   / Deere Loader Stuck Up #2
Check the hydraulic hose connections
Thanks, I have done that, but will recheck tomorrow - Troy
   / Deere Loader Stuck Up #4
There is a lock for the joystick but it generally wouldn't allow one function to not work like you described. Check the lock anyway. It's normally not used and forgotten about.
Thanks, the lock, I played with, is in top position. Still don't know what the middle position is for, but bottom stops all movement.
Troy
UNUSED CFG INDUATRIAL SSECAG-Y AUGER BITS (A51244)
UNUSED CFG...
ECHO SRM-2210 GAS POWERED WEED EATER (A51244)
ECHO SRM-2210 GAS...
2018 CATERPILLAR 249D SKID STEER (A51242)
2018 CATERPILLAR...
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
Walking Floor Trailer (A50322)
Walking Floor...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
