deere f725 mower governor
   / deere f725 mower governor #1
laurencen
Veteran Member
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
hi, story had this mower for over 10 years, last year the plastic can gear lost teeth, I replaced the camshaft with the all steel shaft/gear, oil pump gear the governor looked OK put it back together and worked fine, last couple weeks the motor will change RPM for no reason, idle will speed up and just finicky for RPM control requiring minimal throttle to go from idle to full RPM.
tried adjusting the governor lever to the book and no different, there seems to be no rotation on the governor shaft to the linkage that would control the butterfly of the carburetor, the linkage is such that the throttle lever is attached to a plate that rotates, in turn there is a tension spring that goes to the governor lever, that lever at the end is connected to the carburetor butterfly, the operation would indicate the governor lever should have pressure trying to close the butterfly when the throttle is increased its the tension spring doing the pulling on the butterfly to open it further, there is no direct connection mechanical to the throttle and butterfly.
Im thinking the governor gears are stripped, it seized or the weights are stuck, either way its another tear down of the motor, am I missing something on the operation of this governor setuo
thanks
   / deere f725 mower governor #2
Nope, I think you had diagnosed the problem correctly.
Hind sight is always 20/20. You should have replace the governor assy when you changed the camshaft gear.
Richard
thanks Richard, agree it was a 70 dollar item and chose to not replace not because of cost but it looked fine and no tight spots, at least this time just drain fluids, pull motor and turn upside down to get at it, still a few hours another odd issue, the mechanical fuel pump quit pumping prior to cam gear stripping teeth, figured the pump caused it, since being back in service gone thro 2 pumps and last month installed a electric pump bypassing the mechanical.
guess I will fight it till fall and pull it in the shop
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
Rear Tine Garden Tiller (A51573)
Rear Tine Garden...
2023 John Deere 8R 280 MFWD Tractor (A53342)
2023 John Deere 8R...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
