Deere 870 clutch problem
   / Deere 870 clutch problem #1
WagonRanch
Northern California
Lamborghini R-360; John Deere 870
I have a John Deere 870 tractor. The clutch will not fully disengage when the tractor is hot, but shifts OK when first started. The clutch linkage is properly adjusted as per manual with 1/2" free play measured at the pedal. Why would the clutches be dragging? Is there any way to adjust the dual clutch other than the linkage without splitting the tractor? I know that there are adjustment bolts on the clutch pack, but don't know if they can be accessed from the little port on the side of the housing or if they will do any good. Both the traction and PTO clutches drag.
Also, if I do split the tractor does anyone have feedback on aftermarket rebuilt clutch packs? I'm assuming at this point that I'll want to replace the entire unit instead of just the clutch disks, but obviously don't know yet.
The dealer wants $4,800 to do the job, but he's charging something like $2,600 in parts.
Any advice would be appreciated as I'm not sure to trade up or fix.
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
Ih 1066 Tractor (A50514)
Ih 1066 Tractor...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
John Deere 980 Field Cultivator (A50514)
John Deere 980...
