Deere 855 wheel weights
   / Deere 855 wheel weights #1
WinterDeere
Super Member
Philadelphia
John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
So, I got a set of wheel weights for the 855, some oddly shaped little things. Trouble is, it's not clear which way they should face when mounting them on wheels set to the "wide" position (valve stems in), and I can't find a bit of documentation showing them mounted on wheels set wide. Any wisdom?
The loader manual tells me the rear wheels must be set wide, but the only photo I can find showing wheel weights mounted clearly shows a valve stem on the outside (wheels set narrow). I tried mounting the weights facing both ways on my wheels, and they don't quite seem to fit (without a little forcing) facing either way.
2007 JOHN DEERE 7630 TRACTOR (A53843)
2007 JOHN DEERE...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
Utility Trailer (A52377)
Utility Trailer...
WOOD GRABBER FOR MINI EXCAVATOR (A53843)
WOOD GRABBER FOR...
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
CASE 580 (A47477)
CASE 580 (A47477)
