deere 750 compact right rear brake arm frozen how to lube?
   / deere 750 compact right rear brake arm frozen how to lube? #1
mr_trot
jd 750
pulled side cover and it all came out with the brake shoes attached. The arm is frozen in place and I want to lube cant figure how to get it apart... don't see any snap ring on shaft and parts diagram only show PACKING which i think is just a rubber oring. Don't want to break it ... can anyone tell me how it is retained in cover?
amd
   / deere 750 compact right rear brake arm frozen how to lube? #2
I don't believe it is retained. The shoes clamped into place against it is probably all there is. If it's all rusted up inside your best bet is to strip off the shoes and press it out. Or clamp it in a vise and try breaking it loose with a large wrench. That might might work for you. I've had some luck doing it that way.
1264 (A50490)
1264 (A50490)
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
UNUSED RAYTREE RMDM70-70" HD DISC MULCHER (A51248)
UNUSED RAYTREE...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
(1) VISSANI REFRIGERATOR (A51248)
(1) VISSANI...
Charlotte County (A50323)
Charlotte County...
