DEERE 54" BLADE CUTTING EDGE HELP
   / DEERE 54" BLADE CUTTING EDGE HELP #1
hawk7
Bronze Member
St. Louis Area
4115 Before
Well, I was looking at the bottom of my blade today and I have worn it down into the bolts that hold the cutting edge on. I still have enough steel to re-drill the blade. I can use the origianl hole as they are 1/2 moon shaped now. It looks like the original set up had washers that were bent over and welded to the blade.
My question is how far should the cutting edge stick down past the bottom of the blade? Also if anyone has a newer blade and wouldnt mind taking some detailed pictures of the back of the blade down toward the bottom and a good side pic showing the cutting edge, That would be a big help.
THANK YOU.
UNUSED RETRACTABLE AIR HOSE REEL (A54757)
UNUSED RETRACTABLE...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
30ft Highway Trailer Co. Lowboy (A55218)
30ft Highway...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
