Deere 5105 overheating
   / Deere 5105 overheating #1
ericm979
Super Member
Santa Cruz Mountains CA, Southern OR
Branson 3725H Deere 5105
The Deere 5105 I bought with a piece of property is overheating. The only sign is the gauge, which when I work the tractor heads into the red within 5 minutes or so. It's not steaming out the radiator overflow. There's no oil in the coolant or coolant in the oil. I replaced the thermostat but the symptoms continue. When I run the engine at idle from cold and let it warm up, the top of the radiator where the hot water enters gets warm but the rest of the radiator stays cold. When I squeeze the upper hose from the thermostat to the radiator I can't feel any water moving. Looking in the radiator opening I don't see water moving. If the cause was the radiator being partially clogged I think I'd see water moving in it. What l can see of the radiator looks pretty clean inside.
I think all this means that the pump isn't pumping. Does my analysis sound correct? The fan belt's tight.
Also the pump looks to be $450 or so from Deere though there are cheaper aftermarket options. The rebuild kit is $80. I have not rebuilt a pump like this. Does it require a shop press to get the old shaft out and new shaft in? I have limited tools at this property.
   / Deere 5105 overheating #2
Sounds like the pump to me, but first clean the radiator REAL good. you should be able to get clear water through the radiator coil. Don't use the stream on the spray nozzle, so you don't bend the fins. Personally, I use SimpleGreean and a wand with rating head with a flat spray.
All I had was an air compressor, so I blew out the radiator fins with that. I got a lot of dirt out. But I think if the problem was only that the external fins were clogged the whole radiator would get warm, and also when run for a while it would start blowing coolant out the overflow hose.
   / Deere 5105 overheating #4
Could be something up with the engine computer that runs the gauge.
When my JD started showing overheating on the gauge but no other symptoms I was stumped. I replaced the thermostat, sender, fluid, checked everything and it still showed overheating on the gauge - but no other signs of overheating. The engine felt and smelt right. I couldn't feel heat in the hoses, and a mechanical guage I taped to the coolant return line showed that the temperature was normal.
So I talked with the JD service tech who said that was a common fault. He had seen it so much they kept the parts to fix it on hand. Said it indicated a problem with the multi-wire plug to the engine computer and sometimes the computer itself.
He was right. BTW, it requires JD to program the computer. You cannot do it yourself.
I think this 2005 model doesn't have a computer. But the problem could be in the gauge. I have seen a few threads here from people with 5105s who have had the gauge in the cluster go bad. But those usually have the gauge not resting on the pin when cold, or pinning the needle immediately when the ignition goes on. My gauge mostly acts normal except it goes to hot too easily.
   / Deere 5105 overheating #6
For how long are you running the motor? On my 5205 the temperature gauge needle goes up almost into the "red zone" when the motor is warming up but then drops back down a bit once operating temperature is reached, presumably when the thermostat opens.
   / Deere 5105 overheating #7
Still worth checking. Mine is a commercial model 310 from 2006 and the changeover for those was in 2001. What it has is a pretty primitive engine computer since the motor is still individual injector type. This was before common rail injection & real computers yet.
For a few months mine would crawl up to operating temp like usual, but then continue on up to hot and finally to full hot.....just as though it really was not cooling properly. And the gauge looks just exactly like an old style analog needle gauge from the previous era, even though on this one it is actually the computer which is moving the needle in digital steps.
It may be worth a quick check to see if your 2005 model 5105 has an "John Deere RE522515 (or similar part #) Engine Control Module" also called an ECM. I'm curious too. I almost bought that same tractor.
luck, rScotty
   / Deere 5105 overheating #8
Might be worthwhile to check the temperature with a digital thermometer at different points on the engine, radiator, water pump and thermostat just to see if there are big temperature differences. Also to see what the temperatures are at. I know this isn't completely conclusive but might give some insight as to what is going on. The machine might not be overheating at all.
Though not seeing even the slightest bit of water flow or turbulence at the radiator cap opening seems to indicate the water pump.
Just a thought.
Hmm that's interesting.
I ran it for about 20 minutes cutting grass, then parked it for a few hours while removing irrigation pipe and fence wire from a field with 3' high grass, then fired it up again. I got maybe 10 minutes more grass cutting before I looked at the gauge and it was pinned in the red. I drove it back to the shed and parked it. It was a pretty hot day.
After that I cleaned out the radiator external fins, replaced the thermostat and cleaned the air filter.
Since then I've tried cutting grass and the temp climbs into the red in about 10 minutes. If I let it idle it goes down some but goes back into the red when I rev it up to move it or mow. Mowing pins the gauge if I run it enough.
   / Deere 5105 overheating #10
Is the radiator hot after 20 minutes of run time? If it is not, then I would suspect a water pump problem.
2002 KENWORTH T600(INOPERABLE) (A48992)
2002 KENWORTH...
2022 Club Car...
82" Pallet Fork Extensions, New (A47371)
82" Pallet Fork...
2013 FREIGHTLINER CASCADIA DAYCAB (INOPERABLE) (A48992)
2013 FREIGHTLINER...
2011 Terex Fuchs MHL340 Wheeled Material Handler (A49346)
2011 Terex Fuchs...
2020 BIG TEX 22+5 T/A GOOSENECK TRAILER (A48992)
2020 BIG TEX 22+5...
