I have a 2003 4710 e-Hydro with a 460 loader and 330 hours on it. I bought it at an auction this summer and so far have just used it for light bush hogging and haying on level pasture. I have not tried to (or needed to) engage the MFWD for a while. Soon after I bought it I hit the MFWD button and the light came on but I was on dry level ground and wasn't really under a load so I really never thought about it and since I didn't need it, I turned it back off.
Until yesterday. I was pushing some heavy snow with a blade on the front loader. I hit the MFWD switch before I started. I pushed off one pass, and went to back up in the snow and my rears started slipping, but the fronts were doing nothing. The light on the MFWD switch was on and there was no error codes blinking. Then just for grins today, I chained myself to a small tree I've been wanting to pull. I tighted up the chain, until the rears started digging, and the fronts again were doing nothing.
Looks like a problem, huh. I have been doing some reading and searching and most advice seems to suggest checking the electrical connectors and fuses. I have not checked these yet and I can't do that until tomorrow. Has anyone else had this issue, and if it's not the connectors or fuses, is it likely a dealer service call?
OH also, the red petcock for water/sediment drain on the right side behind the Forward/Reverse pedals I found has a slow drip and I can't seem to get it to stop. There is a hose clamp that is very difficult to get to and I suspected that it might be a little loose, so I finally found a little 8MM wrench and gave it a couple of tightening turns. I stopped because I was afraid of over tightening. I still seem to have a very slow drip. Any hints on that too? Thanks.
