Deere 4320 questions
   / Deere 4320 questions #1
sparker133
Green bay, Wi
2013 Deere 4320 cab, 180 loader, 485 backhoe, 2021 Deere 1023e, Vermeer trencher, 2022 Deere 26g
I just picked up a used 2013 4320 with cab, 180 loader and 485 backhoe with 180 hours on it.
I have a couple of questions about the loader and rear remotes that were installed.
About the rear hydraulics, the dealer installed two extra rear remotes. I wanted them to install a switch to control each one on the control panel. Instead they installed a diverter switch to control them by the loader joystick. Would it be hard or possible to change the way they are operated.
The other question is about the loader joystick is how much movement should be in the stick. It seems like it has quite a bit of movement before the hydraulics engage. Is there adjustments to remove the amount of play in the joystick or is this normal.
Or would it be easier just to add more rear rear remotes controled by switches and leave the ones controlled by the joystick. Is this possible because of the backhoe. I would also like to add a 3rd function for the loader on the joystick.
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Case IH 1063 Corn Head (A50514)
Case IH 1063 Corn...
2009 Chevy Silverado (A47384)
2009 Chevy...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
