Trevj
- Joined
- Sep 23, 2012
- Messages
- 35
- Location
- Interior British Columbia
- Tractor
- BCS, FE-35, Mitsubishi 2500, Gravely 524 project
Got lucky (maybe
) and bought a JD425 with a 54 inch deck and a snow blade.
Was a bit of a crapshoot, but I think it paid off. The description said it had engine problems, which after an hour or two digging about, it seems the engine problems were some broken or missing wires.
I found that the fuel pump disconnect wire was clipped off at the loom and at the connector beside the engine. Replaced that, and reattached another partly cut wire. It looked like it had been chewed by rats.
Anyhoo, got the fuel pump working, drained the skanky gas out, and the engine fired right up, and purred. Nice!
Problem is, the engine cuts out when the PTO(front only on this one) is engaged, or when the brake is released.
Anyone had similar problems? Where was the fix?
I figure I can bypass all the interconnects and run it like any other implement, or I can dig through it and figure it out, and run it as it was supposed to be. I'd rather have it the way it is supposed to be.
While I was mucking about, managed to short the key switch to the frame, there was a puff of smoke from a trace on the electronics board. I ran a bead across that, and all seems well there. I'm not at all adverse to soldering in some new components, if I have to, as there does not seem to be any IC's on the board, just a couple relays and some other basic discreet components.
But if it comes down to it....Not afraid of buying factory parts, either.
Anyone run into this type of problem in the past? I'm wondering if someone rewired something in backwards, or if there is a stuck switch in the system.
Am printing off the troubleshooting guide from the shop manual I found online. <sigh> Things to do...
Any inputs appreciated, thanks!
FWIW, I got the tractor and attachments for just over $1K. Shows a bit over 2K hours on the meter, but was a government owned machine, so seems to have seen real and regular maintenance, at least for most of it's life.
Have not yet checked for the cam gear. Will soon.
Trev
Trev
