Deere 4100 Questions
   / Deere 4100 Questions #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
Anyone know what front mount snow blades fit the 4100? Need the one that is quick interchange with the snowblower. Are the blades from the 700 series garden tractors the same? Can I reference a serial number anywhere online?
Also would like to know how a mid-mount mower for the 4100 is raised and lowered. My 4300 has a hydraulic with linkage that raises the deck. My old 770 used the 3pt hitch to raise the deck.
   / Deere 4100 Questions #2
To my knowledge, the 54" Blades are all the same, but the mounting is different. You could use JDParts to help...Are you trying to find a new or used blade to fit your QH?
The MMM is raised by linkages and brackets that go back to the 3PH, probably very similar to your old 770
I didnt see any front blades listed under the JDParts for the 4100. I am looking for a used blade but would like to know which tractors' QH's match the 4100.
I thought the MMM might raise with the 3pt cause I didnt notice any extra control levers for it. Can you "lock" your MMM up for 3pt use?
   / Deere 4100 Questions #4
Look under the 4110, it's the same machine with some different sheet metal.
I can lock the MMM up, but it requires another "kit" to do it. I posted some pictures in THIS thread of the kit, you could make it yourself...
   / Deere 4100 Questions #5
Only the blade portion of the blade is the same as the other series of tractors (700, etc). The snowblowers, too. The angle / lift portion of the quick hitch is different for each tractor series. Also, ther is likely a drive shaft kit and perhaps some hydraulic hose setup you will need. The angle kit is optional - needed for the blade and broom, but not used for the snowblower.
- Rick
What is different with the angle kit between the 4100 and other series?
   / Deere 4100 Questions #8
The snowblower doesn't use the angle kit - the quickhitch is locked straight forward by a pin dropped through a hole. So if all you have is the snowblower, you probably don't have the angle kit since deleting it saves a few hundered dollars.
The angle kit adds a hydraulic cylinder and hoses that can angle the blade left to right. When you swap out the snowblower for the blade, you pull out the pin and connect the angle cylinder hoses. When you switch back to the snowblower, you drop in the pin, disconnect the angle cylinder, and connect the snowblower chute to that hydraulic circuit instead.
JDParts.com has great listings of all the various parts and kits for most every tractor they make, and I am sure the dealer could help you as well.
I'm asking if I can use an older cylinder from a 318 tractor for my angle. I can find a bunch of those around here. I think they are 8" when cylinder is closed. Get some line made up and I be good to go.
   / Deere 4100 Questions #10
I doubt the 318 cylinder is going to give you a long enough stroke. That cylinder is also a double acting cylinder and most set ups use single acting cylinders for angle functions. You could use a double,but not the perfered way to go.
Sincerely, Dirt
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
HONDA EU2200 INVERTER (A50854)
HONDA EU2200...
2020 KUBOTA RTV...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
Rhino 116 Flex Wing Offset Disc Harrow - Heavy-Duty Tillage Tool - Selling Absolute, No Reserve (A51039)
Rhino 116 Flex...
1264 (A50490)
1264 (A50490)
