Backhoe Deere 310D brakes dragging at random times
   / Deere 310D brakes dragging at random times #1
jason310D
Mansfield, Ohio
John Deere 310D (1996)
Good morning all, I have a 1996 310D machine. I am having a hard
time figuring out why my service brake are applying themselves at random
times without me pushing the pedal. I will just be moving across the field
going after a round bale and the brakes will gradually apply themselves until
machine stops. Let it sit a minute then all is fine. Any ideas? Thanks
   / Deere 310D brakes dragging at random times #2
If the brake valve on the 310D operates similar to the older tractors I can't imagine how the brake valve could be at fault. I wonder if the reverser control valve is letting pressure get into the forward and reverse circuits momentarily at the same time. You might could install a gauge in the reverse valve test port and see if gauge ever gets pressurized while operating tractor.
I will definitely have to check into this gauge idea. After it did this, I noticed that the trans oil now smells burnt. It is relatively new oil too. Just last weekend I worked this machine like no other on a side job for 11 hours straight. Moved over 320 tons if dirt and dug a ditch and didn't have a single issue. Then just light use moving a round bale it gives me fits. :)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
2016 Bobcat E32i Mini Excavator (A50322)
2016 Bobcat E32i...
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
John Deere 47" Snowblower (A50774)
John Deere 47"...
White 255 Disc (A50774)
White 255 Disc...
