Deere 27C grease fittings
   / Deere 27C grease fittings #1
tundraman01
I don't know anything about grease fitting sizes. I have to replace a couple on my Deere mini. I'm guessing they're metric because a metric socket fit perfect to remove them. The threads appear tapered. A couple appear to be 10mm. One of them has threads that measure about 9.44mm diameter. Any help info would be appreciated.
I found the answer on another site. They are BSPT or British Standard Pipe Tapered. Who knows why. It sounds pretty obscure to me. $5 to $8/each from the dealer!
   / Deere 27C grease fittings #3
You can look online and find a assortment kit...
   / Deere 27C grease fittings #4
BSPT is not an unusual thread style just not common in the USA as NPT. Should be able to find fittings at any good parts store. M6 is another common size used on zerks that looks very similar to 1/4-28
2011 Dodge 2500 Big Horn Pickup (RUNS) (TITLE) (A50774)
2011 Dodge 2500...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
International Tandem Dumo TRUCK (RUNS)(TITLE)(LOCAL TOWNSHIP) (A50774)
International...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52748)
2017 Ram 5500...
