hanson1999
I just added a two spool hydraulic valve to my 2520. i tapped into the ports behind the scv block like i have seen on this website. i put the plug in the block. all is working, but the valve sometimes has a vibration/shuddering/squealing noise to it. if you run the levers back and forth you can get it to quit. but if you use the loader or 3 point it may come back after using one of them. anyone have any suggestions?
here is the valve i used.
Burden Sales Surplus Center Item Detail
i put the supply line from the back port of the block on tractor to the "P" port on the valve and the "T" port goes back to the front port on the block on tractor. the valve had no instructions so i'm assuming this is hooked up right?? could it be backwards?
