Deere 2520 & CMI Dump Trailer
   / Deere 2520 & CMI Dump Trailer #1
sneaky
Just bought a CMI tandem trailer. Have had it welded in places where the production welds were limited. Now I am seeking a cylinder and control for the tractor. I don't know much about cylinder specifics and it seems the links from past discussion on the board don't work well.
The 2520 has a power beyond kit and it runs a Rankin log splitter just fine. The rating for the GPM is 10.5 and the implement 5 with a PSI of 2418. The Deere power beyond kit sort of loops in from the top of the back right fender of the tractor. I'd like to put a control valve there so I can operate the dump while seated on the tractor.
Any ideas on cylinder and control valve would be very welcome. :)
   / Deere 2520 & CMI Dump Trailer #2
Welcome to TBN:D
The CMI wagon where discussed a LOT here on TBN a few years ago-not much mention of the lately though. Try a search for some great reading about mods some made to them.
IIRC a 4x24" cylinder is used for them, similar to a logsplitter cylinder.
You can certainly plumb a valve into that loop, do you just want one to operate the wagon, or do you want extra spools and have it permanently mounted?
Thanks for the response, kennyd. I've trolled the forum for the mods. Found some good info, too. A lot of the links are broken.
Anyway, I am learning.... But, I am figuring it out.
I'd like to plumb into the Deere PB loop and mount a control valve near the PB port.
I guess I have simple questions like whether a SA cylinder will suffice and if a control valve like the RD4100 Hydraulic Monoblock Directional Control Valves will work.
Question regarding the PB plumbing option for the RD4100 valve, is it necessary if plumbed into the current PB loop?
Thank you!
   / Deere 2520 & CMI Dump Trailer #4
That RD valve is HUGE, so consider that in your decision. There are more compact valves available, look at the Surplus Center.
As to the PB...there is no readily available return-to-tank line on the smaller JD's, so using the non-PB open center valve will work, although some will post in this thread that the valve will blow up-But mine is working fine as well as MANY others plumbed this way. It's the same as a logsplitter or backhoe plumbed in without PB.
There are quite a few threads also on adding remote valves to 2520's...
Been looking at all of the 2520 valve control implementations on the site. They look really good. Yes, this situation is no different than the Rainkin log splitter I have whereby the control valve is on the log splitter instead of the tractor.
Question though with the sizing statement you made. When you mean HUGE do you mean the size of the control or the capacity? :confused:
Looking at Prince's web site and Surplus Center, there are seemingly hidden pages and not all product available is advertised.
So, a bit challenging to find all options. For example, an Eaton 5 GPM 2 spool valve does not appear in the Control Valve section of Surplus Center. It seems like this unit in a single spool format would work great.
Thoughts?
   / Deere 2520 & CMI Dump Trailer #6
Thoughts?
Yes, I meant physically HUGE-as in real estate required to mount it.
9-4500 is the single spool valve, They are listed in the catalog-but must be out of stock now. They may have stopped carrying it due to slow sales-most people opt for a 2 or 3 spool valve.
If you just want a cheap valve to operate your trailer, you can opt for a simple Prince valve like the 9-6764.
Okay, thanks!
The RD4100 is 6.8" long (w/o handle) x 4.4" wide. The 2 SPOOL 5 GPM EATON CESSNA 30922 is 6.75" (assume w/o handle) x 4.75" wide. Certainly much more compact! Thanks for making me think. ;)
I read a statement you mentioned in a different thread describing your neat looking implementation. Is this the same Eaton valve you would have used if you could do it over again?
On the "wiring" side, the PB sleeve appears available for the Eaton (looks like it is), then the existing Deere PB would connect into the PB sleeve (would there be two for in/out?) and the dump cylinder into one of the spool in/out, correct?
   / Deere 2520 & CMI Dump Trailer #8
Okay, thanks!
No problem:D
Yes. The valve I used did not come with handles so I had to make my own and that was a big PITA! For the velve dollars I save it was not worth the extra effort.
If you use the PB plug, you will have to find a place to connect the OUT port to the tank for a low pressure return...I am not sure there is a easy way to do that.
Without the PB plug (like I did and the others with the 2520's) you will just use the IN and OUT ports.
Dump cylinder connects to the "work" ports on the valve.
Okay, thanks! Having read though a lot of the discussions on PB and such, I am curious what the repercussions are to not use the PB adapter for the Eaton control valve. Seems like little to nothing.
Also, once I get everything installed, I'll upload pictures and other info. The trailer has been stiffened a bit, but only by adding more welds as the production welds were pretty sparse.
   / Deere 2520 & CMI Dump Trailer #10
Re-read post #4...
Basically there is pressure created on the OUT line when the downstream valve is actuated that "could" cause the valve to fail.
Wolverine 72" Skid Steer Sickle Bar Mower (A50515)
Wolverine 72" Skid...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2021 Toyota Corolla LE (A50324)
2021 Toyota...
IH 686 Tractor (A50514)
IH 686 Tractor...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
