Rotary Cutter Deere 2520 - Can it be used with a Howse 500 brush hog?
   / Deere 2520 - Can it be used with a Howse 500 brush hog? #1
hacksaw11111
Deere 2520
Hello everyone. I recently inherited the maintenance duties on my parents property after my dad past away. He had a Deere 2520 and an old Ford 8n (or 9n not sure).
Anyway, the ford is not running and has a Howse 500 brush hog attached to it. I was wondering if I can hook this up to the Deere? Also, if someone knows what, if any, modifications would be required?
I don't have a lot of knowledge on tractors, but hopefully someone here can lead me it the right direction to get this working.
Thanks in advance for the help!
   / Deere 2520 - Can it be used with a Howse 500 brush hog? #2
I think it will run it just fine. Does the 2520 have a frontend loader? If not, you may need some weight in front, but that's about it.
It should hook right up to the JD, but just make sure that the PTO shaft has enough free movement to move with the machine. If it's too long and jams into the case it could break the gear case. +$$$$$$. Conversely, you don't want it fall apart either if its too short.
Thanks. yes it has a front loader. I'll look up some videos and research how to hook up PTO's and free movement. I'll have to see if the neighbor can come over and let me know about the free movement...not sure how I test for that. The brush hog manual talks about shorting the shaft, so that maybe necessary...idk.
   / Deere 2520 - Can it be used with a Howse 500 brush hog? #4
Should be fine. May have to take 1/2 a bite or go slow in think grass or hills.
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
2011 FREIGHTLINER CASCADIA (A50854)
2011 FREIGHTLINER...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A51222)
2020 INTERNATIONAL...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
