Deere 2320 pto shaft turning slowly ?!
   / Deere 2320 pto shaft turning slowly ?! #1
mx125
Toronto
JD 2320
I recently replaced drive shaft and output shaft for second time from dreaded u joint failure.
All seemed fine after. Today using brush hog… all good, but after period of time cutter was slowing and see that pto shaft slowing to crawl. Lift cutter and wait and ramps up again. Engine rpm was fixed. I did not know this was possible !! I thought the engagement literally moved a gear and locked to engine rpm. Ie it either moves or it doesn’t. Not a fluid connection. Any ideas at all ? Did i do something on hydrostatic transmission side ? Very confused and concerned.
Thanks.
   / Deere 2320 pto shaft turning slowly ?! #2
I would suspect your PTO clutch if it's slowing under load.
Check the Deere parts catalog under PTO CLUTCH AND SHAFT - ST149818
   / Deere 2320 pto shaft turning slowly ?! #3
I'll agree withe the clutch assessment. The PTO does not drive directly from the engine. I was advised by a mechanic to depress the clutch when engaging or disengaging the PTO to prevent damage or wear on the gears. I do not know if the HST is involved or not. I've never depressed the clutch then tried to go. Perhaps I should try that. If the HST is through the clutch as well it will start slipping, too.
Oil Well Pump Jack with Motor (A49461)
Oil Well Pump Jack...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2023 John Deere 8R410 MFWD Tractor (A52128)
2023 John Deere...
