I finally got them and they confirmed that they were having telephone problems. I think I am going to buy their low end commercial setup for digging 250' with the casing and screen as well as a roller cone bit for rock. It will cost me $8K delivered. I need to drill three wells and I expect to have one or two that won't recover fast enough so assuming only 3 250" wells at the going rate here of $11/ft I will break even assuming the rig works. As soon as I drill a dry hole, I will come out ahead. Now I need to learn to witch to find the best spot to drill. Actually, I don't think I would trust a water witch to find water at the depths we have to drill here. There is water at fairly shallow depths but it would not yield enough water to be useful and would likely dry up in severe droughts like we are having this year. (only 4" of rain since February).
I don't think I would gamble on this thing working in the granite around Marble Falls though. I have hard limestone around here but it is still a lot softer than granite. From what they told me, their rig should drill through the hard limestone at 2 - 4 in/hr which is faster than the drilling speeds I get with my 9" Beltec auger but then the drill is much smaller. I have a 2" carbide PHD bit that drills fairly fast but I use a lot of down pressure on it. The rig I am looking at uses 1 3/8" drill stem so you cannot put much down pressure on it especially at deep depths. The next step up is to 1.9" drill stem and the price goes up exponentially or so it seems.
