CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 5,771
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
Around my lot, I have a situation where I need to break through DEEP snow.
I have a useful arsenal of snow moving equipment, but still seem to think "there must be a tetter way".
There is is a gentle down grade that gets piled with snow from blowing the drive. It's about 30 meters to a bank that can accept as much snow as will ever be seen, but the entrance to that bank is only 2 meters wide, and often choked with a meter depth of snow blower compacted snow. At present, I've been driving over/ through the depth with the loader and back blade fitted Hurlimann 435.
Trying to use the front bucket bogs the tractor in the depth of snow. Should the bucket lift and pile each advance, one before the other? I have not had good luck with this effort so far. perhaps there is a technique. Due to the presence of trees and the lay of the land, a straight on advance is the only option.
With the recent snow, I was "almost" stopped, but the Hurlimann's front and rear locking diffs prevailed, and an initial path was made on wheels alone. Once through the deepest portion (and that took some time) The back blade was used to haul the snow forward, then backed over, then bucketed over the bank while hauling a new back blade's worth to the ready position. It must have taken 15 cycles to clear the 30 meters. Then a similar process was used to widen the path before turning the back blade 180 degrees and pushing the load in one go.
Are ther better techniques to the breaking through effort?
The blower that fills the avenue described above, is mounted on a Bolens HT-23 that throws the material off the drive and into the confines. That piece of equipment is deficient in several ways. The blower is only as wide as the wheel track,(I'm looking for a 48 -54" blower that accepts the Bolens HT rotation direction) and backing out of any advance is difficult. Even though fitted with wheel chains, the yard tractor will hardly get out of it's own way. It could sorely use four wheel drive! I've dug it out of it's own mess two many times! (but man-o-man does it blow snow on the easy going!)
So just a shout out for good suggestions into how to "break through" and then move considerable amounts of snow with "smallish" equipment.
The Fordson, though fitted with aggressive wheel chains and a most useful front mounted Western plow blade, runs into traction problems early on. The area to be cleared has a nasty habit of being icey! That and the fact that it is stored at the bottom of the area to be cleared , safely tucked under the lower level of the shop, and the reason the snow needs moved in the first place ;-)
Ideas welcomed
Ideas welcomed
