Deep Cycle Battery in Pickup
   / Deep Cycle Battery in Pickup #1
Mudfarmer
Western Washington
JD 3005, Kubota B2710, Kubota B2650 (sold the ford 1700 and kubota B7100)
I have two batteries in my 2011 Chev Silverado PU attached in parallel to the alternator. One is for the pickup the other for winch, inverter, etc. The latter is near the end of it's life. My question is can I replace it with a deep cycle battery; will the alternator charge a deep cycle battery without difficulty; if my main battery goes dead can I jump-start the truck from a deep cycle battery?
MF
   / Deep Cycle Battery in Pickup #2
MF
If they're hooked up in parallel, how do you separate their work load? Is there a battery isolater in there somewhere?
In answer to last two posts: Professionally wired regulator - I don't know anything more about that. Gas engine.
   / Deep Cycle Battery in Pickup #5
MF
You may need to look up and understand what happens to batteries if they are truly in parallel.
If they are protected between eachother, the second one might not be damaged. If they are not, the other battery is likely already damaged from over charging.
   / Deep Cycle Battery in Pickup #6
You should have two like batteries i.e. Same capacity and health. If one is down it will always drain the other one. Also there is a risk of overcharging a lower capacity battery to bring the bigger one up to full charge.
   / Deep Cycle Battery in Pickup #8
The two batteries are protected from each other.
Then you probably have a battery isolator in there somewhere. In that case, there would be no problems installing a deep cycle for the winch. The other battery will handle the starting. But they aren't exactly in parallel, if that is the case as well.
   / Deep Cycle Battery in Pickup #9
I’ve seen what he’s talking about. Offroaders install a kit so that running the winch, lights, and/or other utilities use a different battery than the starter and other necessities. Generally they also upgrade the alternator.
Most likely what the rest of you are calling a battery isolator? 🤓
   / Deep Cycle Battery in Pickup #10
What does the owners manual say about battery replacement/separation?
Here are a couple basic battery rules. Batteries that are in parallel with no separation; if you replace one, the weaker older one will become a parasitic load on the new battery. In this case, you replace in pairs. A deep cycle battery is not designed for repeated intermittent starting loads. If properly separated and controlled, then you can replace either battery without regard for the other.
My experience is in RVs. These will have an electronic separator (diodes) that will allow charging current from the alternator to recharge the winch battery, but not allow current to flow from the starting battery to the winch. In RVs, there is usually a manual bypass switch on the dash that allows using the deep cycle (winch) battery to start the engine in an emergency.
You really need to dig into this and understand your circuit before proceeding.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
2021 CATERPILLAR 279D3 SKID STEER (A51242)
2021 CATERPILLAR...
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
