decompression lever
   / decompression lever #1
pruntyc
Platinum Member
MS
John Deere 4110 HST
Having just traded in my Yanmar for a 4110, I get tomorrow. I was wondering, the old Yanmar had a decompression lever, to make it easier to start when it was cold. And it helped get the motor spinning so the oil pressure could come up, before the engine started. As the new Deere's don't use it, even if they are made by Yanmar, I wonder how it works without one. Maybe more powerful starter motor, or what. Does anyone know the answer?
   / decompression lever #2
Don't know the secret either, but my Yanmar diesel still starts in below zero weather after 6 years, and on the first rev too.
   / decompression lever #3
I added the block heater to my 2210's yanmar motor and it willl start at any temp! But I have started it at down to 0-5 degrees with no "Help" from the block heater and it started pretty good. Smokes for 10-20 seconds but runs smooth after that. I think the glow plugs are a lot better and the combustion chamber and injector designs have helped improve cold weather starting quite a bit.
   / decompression lever #4
The coldest I've started my 990 (with Yanmar engine) is -30 deg C, with no block heater. It clanked and clattered and smoked like crazy and generally complained for a little while, but it started surprisingly easily. It has an intake air preheater but no glow plugs - and no compression release. I also use Amsoil synthetic. I definitely wouldn't try it with dino oil at that temperature. Even if you got it to turn over fast enough to start, I don't trust non-synthetics to circulate well enough at that temperature.
ps. I've since installed a block heater. I don't necessarily recommend "abusing" the engine by starting it that cold on a regular basis.
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
23222 (A50323)
23222 (A50323)
