deckover or between wheel equipment trailer
   / deckover or between wheel equipment trailer #1
KINGKUBOTA
Looking to up grade my trailer Moritz 14000GVW. Have mini excavators and track skid steers. Considering deck over, stationary, tilts or half tilt with front stationary. Or should I stick with lower to ground between the fender trailer. Any suggestions or advice? Thanks!
   / deckover or between wheel equipment trailer #2
I have never used a deckover, but it is what I want. Then again it's because my rotary cutter doesn't fit between the fenders of my trailer and it becomes a circus of creativity every time I need to take it somewhere. My trailer is narrower than some, so I guess just a slightly wider trailer would eliminate the problem, but I want a deckover anyway. They are also easier to side-load with a forklift if you ever use for lumber or pallets or something.
I am not sold on tilt decks. They would be convenient if you were hauling one piece of equipment and did it all of the time, but if you want to haul 2 smaller pieces, it would be a pain. Even a power tilt I wouldn't trust because you are putting an awful lot of weight in front of the pivot point until you get the second item unloaded... I doubt they are made for that. If you have specific equipment that you will use it for and a tilt bed will work, then it would be fine, but if you have a variety of different things to do with it I would skip the tilt. It's not that hard to put ramps down.
   / deckover or between wheel equipment trailer #3
Times 2 on the deck over. Better to load stuff and so forth and are you looking at a bumper pull or a gooseneck?
Thanks Guys
   / deckover or between wheel equipment trailer #5
I have a 20' bumper-pull 14,000 lb. GVW 1/4 - 3/4 split tilt deck to haul my dozer, mini-ex, and skid steer, plus the Dual Dozer. I like the low center of gravity and the easy on - easy off of the between-the-wheel trailers. I can also side load pallets with no problems, just not where the wheel wells are.
   / deckover or between wheel equipment trailer #6
I have a 14k between wheel tilt deck gooseneck trailer and really want to trade to a deckover non-tilt deck with ramps. I'm tired of having to work around the fenders all the time and really wish I had the extra width. It's great for hauling one piece of equipment but that's about it, and i use it for things other than that most of the time. Just my personal opinion/experience
   / deckover or between wheel equipment trailer #7
I think it all depends on how your stuff would fit between the fenders. If everything you have is narrow, then a lower trailer is easier to go up the ramps. However, some of my current stuff would not fit, or would not fit well between the fenders of a lower trailer.
I used to have a lower "between the wheels" trailer. I had about 1-1/2" clearance (total, both sides) loading the tractor. Had to have it just perfect. Current trailer is a deckover, gooseneck. More room and also more side accessibility for loading extra buckets or other attachments.
   / deckover or between wheel equipment trailer #8
Another vote for deck over. Get a 19lb frame, tandem duals, and a gooseneck and your trailer needs are met until you get a 20k+lb piece of equipment and need a 20 ton tag or low boy.
If you have the choice, get a 30k coupler and 12 or 15k axles, derated to 26klbs unless you want to pay FET.
   / deckover or between wheel equipment trailer #9
I second err third, well maybe forth the deckover. I just sold a skidsteer trailer that I used the heck out of until I got the LOW PROFILE deckover. I think its 4" lower? I can easily step up onto and off of it (granted I am 6'2"). If you are planning on carrying more than about 12k lbs, I also agree with the tandem dual suggestion. I also agree with the upgrading of the axles to atleast 10k HD's (larger spindles) if not the 12k axles. My current trailer is a Moritz 20+5 LP with an adjustable tail and it has handled everything I have ever put on it. The only problem is I reallycould use an extra 10' of deck length and upgraded capacity. Funny how things changed in 3 years!
   / deckover or between wheel equipment trailer #10
Any idea of empty weight of that?
2015 WESTERN STAR 4900 (A45046)
2015 WESTERN STAR...
Multiquip DPS-180SST 100psi Towable Air Compressor (A42742)
Multiquip...
AIRMAN COMPRESSOR (A45333)
AIRMAN COMPRESSOR...
Unused Kivel 48" Pallet Fork Attachment (A42021)
Unused Kivel 48"...
2005 Dodge Ram 2500 4x4 Crew Cab Pickup Truck (A42744)
2005 Dodge Ram...
2015 WESTERN STAR 4900 SF (A45333)
