Deck shakes when PTO turned off
/ Deck shakes when PTO turned off #1
davidddubs
Berlin
2015 Toro
Yesteday while cutting a yard, Something didnt' sound right. I shut off the PTO and the deck shook pretty bad. I looked underneath and belt is fine. All pulley's turn easily by hand and blades aren't bent. The PTO turns on fine without any shaking and it cuts fine it's only when I shut off the PTO that the deck shakes... Only have 70 hours on mower..
Any thoughts?
/ Deck shakes when PTO turned off #2
Something is out of balance. Start by looking over all the blades real good.
/ Deck shakes when PTO turned off #3
Make sure the blades are swinging freely. If one gets grass wrapped around the pivot bolt it won't stay in synch with the other and the deck will shake like crazy. I've even seen a piece of wire get wrapped in there as well.
Edit, just realized you aren't likely talking about a rotary cutter, so the above probably doesn't help.
Safety note, make sure you block the mower up with something...a couple of jack stands, etc, before you get under there :thumbsup:
/ Deck shakes when PTO turned off #4
I'm trying to figure out WHAT kind of mower?? Rotary cutter?? Finish mower?? Flail??
All of these would require a difference answer...
IF it's a normal finish mower, the blades wouldn't swing "freely" and there wouldn't be a "pivot" bolt...
SR
/ Deck shakes when PTO turned off #5
Check all the deck fastening linkage.
SR
It's a 2015 Toro Zero Turn 52 "
Thanks I'm going to remove blades and take a look tonight
I will do that as well.. Thanks for the insight. I will let you know what I find.
Thanks. I'll check it tonight and I will let you know what I find.
I'm thinking this site isn't for me... I have a little zero turn and most people on here have those "big tractors"... I appreciate everyones help and I hope I didnt' waste your time
/ Deck shakes when PTO turned off #11
Are you sure it wasn't just clumps of wet grass falling off the underside of the deck onto the blades ?
With my mower deck, sometimes when you throttle it down, the rapid deceleration introduces just a little hiccup that knocks a clump of grass off the underside of the deck, that then causes a bigger shake when it hits the blades, which knocks off a bigger clump and a bigger shake, etc...etc...rinse and repeat.....
/ Deck shakes when PTO turned off #12
Maybe not, but youll find PLENTY pf people here with small machines of all types.
... I would be interested in what you find for the problem.
/ Deck shakes when PTO turned off #13
We have yards to:thumbsup:
/ Deck shakes when PTO turned off #14
Lots of us have zero turns, riding mowers, etc and there are plenty of members who don't have a farm tractor, but find many of the other sections useful. You might find the same thing....lots of helpful people here :)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
213065 (A64276)
213065 (A64276)
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
