Mowing deck 590-811-100 throwing belts
   / deck 590-811-100 throwing belts #1
mike pruden
cub cadet 6284
Does anyone else have a problem with the deck throwing belts? Noticed that the belt will ride up on the middle belt sheave, then return to ride in the groove, does this on and off until you throw the belt. Brand new belt this week, but after numerous tosses, it's now a little ragged. Took the guards off so I could put belt back on. Left them off because of the multiple times I had to do this. help
   / deck 590-811-100 throwing belts #2
I've had the same problem.. so far 100$ in belts. I had three problems that killed 2 belts, 1. Idler pulley bearings were shot. 2. Too much tension on belt. I replaced idler pulley with a smaller pulley. 2. Tensioner pulley arm was bent down and needed to be bent back up. Now it rides in the middle with no problems. 3. Lack of grease in shafts and grease points. I greased the life out of every joint on the deck.
2010 Scion xB Hatchback (A48082)
2010 Scion xB...
2019 Ford Transit 150 Cargo Van (A48081)
2019 Ford Transit...
Generac 15KW Generator (A50860)
Generac 15KW...
2006 Ford F-250 4x4 Ext. Cab Pickup Truck (A48081)
2006 Ford F-250...
2000 ADDCO DH1000 Message board (A49461)
2000 ADDCO DH1000...
2013 Nissan Rogue SUV (A50860)
2013 Nissan Rogue...
