Decision on brush string trimmers
   / Decision on brush string trimmers #1
LSmith
Bronze Member
Brandon, MS
Kubota L3400
Hello All,
I need to clear about 5ac of unlevel rutted land. It is covered in waist to chest high grass & weeds. I am thinking a string type brush cutter might be the answer. I have looked at the Troy bilt and the Murray and they seem to be fairly similar. The Troy has a 22" cut and a 6.5 Briggs And the Murray has a 22" cut and a 6hp Techumesh engine. Warranties are identical. The big difference seems to be price. The Troy is $450 & the Murray is $275. Any opnions or user feedback?
Thanks.
L.Smith
   / Decision on brush string trimmers #2
L. That's a lot of area for a string trimmer. I had a Sears and had a lot of problems with it. I sold it and bought an Ariens which works a lot better, but still gets tangled up occasionally. Using one of those on 5 acres is a lot of work. I use mine to touch up areas I can't get with the lawn mower. If the terrain is not suitable for a 3-pt bush hog, which I take it it isn't, I 'm sorry to say I would go with a DR Field and Brush mower. Sorry because you're looking at 3X the $$$, but it's really the only realistic solution. DR has a money back guarantee. Try a DR string trimmer for a while and if you come to the conclusion that it's too much work, send it back for a full refund including shipping and upgrade to the field and brush mower. JMHO
Pacesetter
   / Decision on brush string trimmers #3
Another idea you may want to consider is a brush clearing saw. I have the Stihl FS 450K. I can take down small trees and sapplings as big a 5" in diameter. It weighs about 20 lbs. altogether and mounts to a body harness. It is not a rotary cutter but can cut down anything a rotary cutter can and gives you more control and versatility as it can accomodate several different cutter heads to include a string trimmer head. Kinda pricey but they last. I have had mine for almost 10 years and it still runs like a champ.
   / Decision on brush string trimmers #4
What are you planning on doing with the land once it's cleared? You may just want to hire it done the first time and then use a lighter piece of equipment that you own after that.
   / Decision on brush string trimmers #5
It would cost a little more (not a lot), but think you ought to look at the DR trimmer/mower from Country Home Products. I had the 6 hp Briggs with electric start and they cost a lot more a few years ago when I bought mine than they do now. I had the 12" Beaver Blade to go with mine so I could cut down pretty good sized saplings pretty fast. And they've added a number of neat attachments to their line now that they didn't have when I bought mine.
   / Decision on brush string trimmers #6
I would rent a heavy duty DR field and brush cutter ( hog type not string ) for ther first pass and then you could probably get by with the cheaper string trimmer if you kept it cut fairly often.
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
2014 Dodge Avenger Sedan (A53424)
2014 Dodge Avenger...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2004 TerraGator 8104 (A53473)
2004 TerraGator...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53473)
2020 New Holland...
Farmtrac 80 2wd with loader and limb risers (A53473)
Farmtrac 80 2wd...
