Deciding to get another grey.
   / Deciding to get another grey. #1
Yandaddy1110
Elk River, mn
Yanmar YM1110D, John Deere 955
I have started a home-based business which involves unloading pallets of merchandise off a semi-trailer truck. No loading dock obviously. Been renting the neighbors skid steer for the task,unfortunatly leaves ruts and tears up the drive and the lawn to the pole shed where I store the mechandise. My question, what size tractor could handle 700lbs palleted loads with a 3ph safely. BTW I have a yanmar 1110d and am very familiar with grey market kubotas,isekis hinomotos ect. just not the 20 + hp types.
   / Deciding to get another grey. #2
Hmmm?
No loading dock...
Pallets on the 3 ph....
Experience with tractors less than 20 hp....
Using skid steer now.....
I cannot piece this one together. What am I missing?
   / Deciding to get another grey. #3
I would use anything less than a 30hp 4x4 w/FEL.
Then, affix pallet forks to the front of the bucket.
What you might also need is an attachment on the rear 3pt for balance.
That's a bunch of weight out front for any compact tractor.
Sorry, I should have mentioned the fact that I would convert a single stage forklift mast that I have to 3PH and use that off the back of the tractor. Mast weighs maybe 300lbs and has a lift cap. of 1000lbs. Another factor is 2wd should be OK for this type of use, and also, I have a loader sitting out back that someday I would install.
Hmmm?
No loading dock...
The skid steer works, its rented from neighbor. Problem is this is semi-rural residential, I want to keep this businesss low impact with the neighbors, the smaller the tractor the better as far as that is concerned. So far semi comes every- other month, so a Bobcat is kinda overkill, plus I would like to have my own machine here when needed and not rely on someone elses machine to be available.
   / Deciding to get another grey. #6
If I misread or misunderstood, please clarify...you are not going to unload a semi from ground level with forks on the rear of one of these tractors. Front forks on something 25HP and 2500# or more, perhaps, bu the 3ph won't lift high enough. It will carry your pallets, but not unload a truck.
   / Deciding to get another grey. #7
Why not get an old US gas farm tractor? Any of the ones which have a standard 3ph will handle the load with ease. Inexpensive, known reliable, stable with a load, good parts, and the gassers start easy in cold weather. Much as I like compacts, this sounds like an application for a good old haying tractor. Your money will buy a nicer machine, too. Put balloon tires - or truck tires - on it for a nicer ride.
rScotty
Yes I am thinking of unloading the semi from the ground using a 3PH forklift mast, single stage which I already have,and should lift 6' high.The mast plus the pallet would weigh aprox. 1000lbs. I have considered a loader with forks, but that is really not ness. with a 3PH forklift mast.
rScotty
I did once consider an old gasser, yes it would work. I would like to remain in the grey compact world though, I dont want old farm machinery in a residential area.
   / Deciding to get another grey. #10
Morris,
I think you are looking at this the wrong way. Re-consider bucket forks.
Add on bucket forks are a great attachment. They are simple to put on, allow you to look forward to drive your load around and there is no design work or hydraulics to figure out.
I use mine all the time for moving just about everything. With my New Holland TC29DA I can carry about 800 lbs max. A bigger tractor would do much more.
2023 John Deere 6120E MFWD Tractor (A53342)
2023 John Deere...
Kawasaki NR (A50324)
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
