N80
Super Member
For years I've been using one of those typical air compressor chucks with the white post that slides in and out to show you the pressure reading. The one I have has always had two problems. It has always been a little leaky and the pressure range that it reads out is like 0-200 psi. This means the scale is so small it is hard to read and it also means that making precise adjustments is nearly impossible. Now it is leaking badly and its hose is falling apart. Time for a new one.
So I am looking for one that is well made. I don't mind spending a little money. I would prefer that it be a double sided chuck as the valve stems on my tractor rears are on the inside of the rim. I would like the pressure gauge readout to be no more than 100 psi. The only thing I ever run over about 60 psi is my trailer tires at 80 and even they don't really need to be that high. At the racetrack I need to be able to make precise adjustments of 1-2 pounds on my car. I do have a high quality pressure gauge to get it just right.
So, what do you guys have that you like that meets my needs?
