Dear trailer manufacturers
   / Dear trailer manufacturers #1
LoneCowboy
Veteran Member
It's 2007, almost 2008
Cars have had sealed bearings for almost 30 years
It's time to get a clue
There's only one part on a trailer that needs regular maintenance.
It shouldn't take hours to do it.
Minimum all trailer should come from the factory with bearing buddy style things, but really it's time to have sealed bearings.
Seriously, get a clue
I, your customer, shouldn't have to get down and dirty for hours to grease bearings every 3000 to 5000 miles because YOU are too lazy/cheap to put real axles on.
Fix it
   / Dear trailer manufacturers #2
So, why didn't you buy the oil bath axles?
But seriously, I agree! Even putting a drilled hole thru the axle shaft and a grease zerk accessable under the cap would be a time saver. The bearing buddies have been known to grease the brakes up good if you go to town pumping and blow out the seal. For that reason many don't use them on axles with brakes.
   / Dear trailer manufacturers #3
X2 i would rather clean and repack bearings than have inoperative brakes when i need them.
   / Dear trailer manufacturers #4
So LoneCowboy- you been hiding under a rock somewhere?:D
Dexter- the largest axle manufacturer, has had sealed bearings for years now- you just have to spec them if you want them.
http://dexteraxle.com/nev_r_lube_bearings
Believe me you DON'T want "bearing buddy" type things on ANY trailer with brakes....the EZ-Lube deal, again a Dexter innovation, with the internally drilled hole with the nipple under the rubber axle cap is a good alternative. Some report trouble with them but I've never had any, I love them. The Bearing Buddy things have a spring and keep pressure on the grease, an ok idea if its a boat trailer without brakes being dunked in the water. Not so good with brakes because they can leak a little grease out the back...the EZ-Lube method does not keep any pressure on the grease.
http://dexteraxle.com/e_z_lube_system
   / Dear trailer manufacturers #5
We use German Knott axles, with automotive style, sealed double row angular contact bearings.
I think sealed automotive bearings is pretty much standard on the axles up to 1500 kg, just the 1800 kg ones have kept the conical bearings. These axles have 2 grease seals to separate dirt from outside, and grease inside. A grease seal failure is very unlikely, most brake problems occur from leaking hydraulic brakes that soak the brake pads.
When i look at the Dexter nevRlube bearings, i have my doubts how these will hold up on tandem or tridem trailers when used on hard surfaces with a lot of cornering.
the EZ lube axle have the bearings at a wide stand, which will deal a lot better with tandem friction.
   / Dear trailer manufacturers #6
I wonderd the same thing too about the close spacing on the Nev-R-Lubes, but then they come with a 5 year 100,000 mile warranty so Dexter must be pretty confident;)
   / Dear trailer manufacturers #7
While we're at it, could we also get the trailer manufacturers to STOP using scotch-lock connectors on most of their electrical connections, ESPECIALLY on the brake wiring down on the axle where it constantly gets sprayed by water and road salt????!!! Really.... on a manufacturing level, how much could it possibly cost them to solder and heat shrink..... OR pre-made wiring harnesses with sealed ( GASP !!!) electrical connectors like the automotive manufacturers use ????!!!!
   / Dear trailer manufacturers #8
And do away with spring ride alltogether. I hate changing spring hangers, shackles, spring bolts and those absolutely useless plastic insert bushings that last all of a week or so.
The closest I have come to perfect is the Dexter torsion ride axles. Now if they would do the sealed wiring harness, we'd be golden.
BTW, why the heck don't trailers come standard with back-up lights? :confused: What's up with that? You wouldn't own a vehicle without them.
   / Dear trailer manufacturers #9
Lets also do away with the 1 7/8" trailer ball- it has absolutely no purpose on earth yet small trailers STILL come with them...over the years I've swapped out many couplers for 2" to hold down the variety of drawbars needed. The latest was my log splitter trailer that I bought just a few months ago....
BTW my Featherlite enclosed aluminum trailer actually has a pre-made weathertight wiring harness...of course it is a high end trailer costing twice what some similar trailers with steel frames do..
   / Dear trailer manufacturers #10
Why on earth are you down there greasing them every 3-5k miles? Seems more than a bit excessive. There has been more than one occasion that 3k wouldn't even make it through a trip.
On both of my trailers the bearings are identical to the ones on the front of my truck; tapered roller with a grease seal. I do them once a year just to be through, but I suspect they could go longer without issue.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
UNUSED RAYTREE RHBC72-72" BRUSH CUTTER (A51248)
UNUSED RAYTREE...
2025 REDELIFT CPD25-XD4 FORKLIFT (A52576)
2025 REDELIFT...
2020 JOHN DEERE R4023 LOT NUMBER 94 (A53084)
2020 JOHN DEERE...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
