Buying Advice Dear tractorholics - need used purchase advice for under $20k
   / Dear tractorholics - need used purchase advice for under $20k #1
Buxus
Maryland
Kubota M7060
Had a new tractor all picked out with all my wants and needs. Came to about $41k for a Kubota (M7060), or $50k for a JD. Not really any other dealers here. My wife said "No, not now. Maybe in a few years."
I rarely buy anything new anyway (big Craigslist fan), and am now wondering if a used tractor would be the way to go.
I had planned on 60HP at the PTO (to turn a 12 ft flail or rotary mower,) a FEL, and soon, a grapple. No cab. Diesel. R4s as it will often be used on turf. Hoped for 4WD. Eventually a rear blade of some sort, and a post hole digger.
The tractor is for property maintenance as I am not a farmer. I have 32 acres. Basically, it's a gorgeous historic estate that was neglected for about 30 yrs and sold in foreclosure to my wife and me in 2012. It has some hills that a 2WD zero turn loses traction on at times. I spend about 80% of my free time on the property (our main home is 40 miles away). Half of the property is mowed. Half of what I mow is finish mowed, half is hayed, but it's a bear finding anyone who will hay it because hay doesn't go for much here. Plus, I really enjoy maintaining it myself. There are overgrown historic gardens, massive specimen trees, and eventually there will be a tiny orchard.
I envision about 100 hours per year on the tractor. I envision using the tractor with a 12 ft mower and finish mow less of it to save time. I envision using the FEL for mulching and soil and compost and manure moving. I envision using the grapple for woods clearing and maintenance. I am a meticulous property owner and never seem to have enough time to get all my projects done. While I understand that a smaller tractor can do just about anything a larger one can do (but that it takes more time) time is an important currency for me. Thus the interest in a larger tractor, mainly for faster mowing. I've rented a JD 35HP with a 7 ft rotary mower multiple times over the past few years, and it feels overmatched with the tall grass and hills unless I crawl along at 1-2 mph. The FEL does the job, but I usually end up wishing for more capacity (for example when distributing enormous piles of chipped wood). Having said all this, several people have said I should get something smaller. I am open to suggestions about size.
So now about the choices. I will not be doing any mechanical work on the tractor other than routine maintenance (e.g. no repairs). It seems to me the options are 1) New Big - $40-50k (in a few years, per my wife) 2) 10yr old Big- $25-35k 3) older Big $10-20 4) Smaller tractor.
I am tempted to start looking at option #3 as a way to get a tractor sooner than later. Plus I won't be using it so much that my hours on it will pile up, and in theory I like the idea of a simpler machine with fewer things to go wrong. From what I read online, there are not too many fans of the mostly imported tractors from the '80s and '90s. This means buying a 40+ year old tractor. Questions about this: 1. Mistake? 2. If not a mistake to buy such an old tractor, what specific models do you suggest as time-proven workhorses that have parts available and have some/all of the features I noted above? Bottom-line what would you get for under $20k, and is Used/Old a better way to go than options 1, 2, or 4 (because it seems a lot cheaper, even with LOTS of repairs).
Sorry for the long post, but thanks for any advice.
   / Dear tractorholics - need used purchase advice for under $20k #2
My impression is that, although perhaps simpler, older still means frequent work/repairs. If you are not going to do it, who will?
   / Dear tractorholics - need used purchase advice for under $20k #3
Look up some of my old threads. Starting with http://www.tractorbynet.com/forums/kubota-owning-operating/269196-new-owner-old-m4700-questions.html?highlight=
Bought in 2013:
298638d1358714706-new-owner-old-m4700-questions-8x6sam_0798-jpg
298637d1358714705-new-owner-old-m4700-questions-8x6sam_0797-jpg
1995 Kubota M4700
1440 hrs
recent fluid/filter change
2 rear remotes
new rears
Purchase price $11,555
since purchase:
2 new fronts $600
new battery $120?
4 hoses ~ $100
1 FEL curl cylinder repair $45
   / Dear tractorholics - need used purchase advice for under $20k #4
My neighbor, the hay farmer, has been trading in his tractors every two years. I bet these tractors do not have over 2,000 hours on them which means good as new, but with 2 years of depreciation. Another farmer down the road that is actually doing row crops buys all his equipment two years old from wherever. He has equipment shipped from out west if he finds something he likes. He is buying these big few hundred horsepower tractors and combines.
Tractorhouse.com for pricing and searches all across the nation may help you with some answers. Not all tractors traded in are worn out or lemons. I see some JD5075s for mid 20's.
   / Dear tractorholics - need used purchase advice for under $20k #5
What does a new MX5800 go for?
   / Dear tractorholics - need used purchase advice for under $20k #6
With a FEL? Around 30K.
   / Dear tractorholics - need used purchase advice for under $20k #7
<snip>
I envision about 100 hours per year on the tractor. I envision using the tractor with a 12 ft mower and finish mow less of it to save time.<snip>
100 hours/year is about like my usage so far on the M4700 (hopefully I'll get to use it a lot more next year). SWMBO finally agreed in mid 2012 that a bigger tractor was needed and it took me until January 2013 to find the right combination of power and price (< $15K).
A new 50 HP Kubota similarly equipped would have cost over $30K then.
With all the other potential uses for my $$ I couldn't justify spending $30K at once to save on maintenance. For $18K I figured I could get a lot of maintenance done.
If the OP gets a good used tractor, by either hiring a decent mechanic to help him buy, or buys from a well respected dealer such as Barlows or Messicks and then engages a good mechanic he should be still able to save a ton of money.
   / Dear tractorholics - need used purchase advice for under $20k #8
60hp PTO, FWA/4WD, with FEL for $20K....that's going to take some luck. The problem with the 40 year old machines (other than that they will require work in almost all cases) is that very few of them had 4WD and many didn't have a loader either. That means the pool of possible choices is pretty limited. It seems to be much more recently when Utility machines commonly have an FEL, and that means you're talking newer, more expensive tractors.
   / Dear tractorholics - need used purchase advice for under $20k #9
I just looked on Craigslist. Around here we have several older Fords in 2WD with loaders going for 15K-20K asking prices. One is a 5900 with 1250 hours and Woods loader. 2012 Boomer 50 4x4 with FEL for 18.5K. TN 75 4WD with FEL with low hours according to owner for 17K. NH TL 80 with Quickie FEL 21K. Local dealer is selling new Workmaster 50's with 521 TL's for 25.5K financed. Cash price is lower. I just traded for one. Tractors are out there if you are willing to drive around and look. Older iron will most likely be in 2 WD form. I did find one in 4 WD. They are not many of those out there and they don't usually hang around long.
*2WD FORD DIESEL 59 TRACTOR
REDUCED NEW HOLLAND TN 75
Workmaster 5 w/ loader
New Holland TL8
212 Boomer 5 New Holland 4x4 Loader
   / Dear tractorholics - need used purchase advice for under $20k #10
I planned on 60HP at the PTO (to turn a 12 ft flail or rotary mower,) a FEL, and soon, a grapple. No cab. Diesel. R4s as it will often be used on turf. Hoped for 4WD. Eventually a rear blade of some sort, and a post hole digger.
The tractor is for property maintenance as I am not a farmer. I have 32 acres. It has some hills that a 2WD zero turn loses traction on at times. Half of the property is mowed. Half of what I mow is finish mowed, half is hayed, but it's a bear finding anyone who will hay it because hay doesn't go for much here. Plus, I really enjoy maintaining it myself.
I envision about 100 hours per year on the tractor. I envision using the tractor with a 12 ft mower and finish mow less of it to save time. I envision using the FEL for mulching and soil and compost and manure moving. I envision using the grapple for woods clearing and maintenance. While I understand that a smaller tractor can do just about anything a larger one can do (but that it takes more time) time is an important currency for me. Thus the interest in a larger tractor, mainly for faster mowing. I've rented a JD 35HP with a 7 ft rotary mower multiple times over the past few years, and it feels overmatched with the tall grass and hills unless I crawl along at 1-2 mph.
LINK: TractorData.com Kubota M7060 tractor information
USED TRACTOR LINK: Industrial Tractors in Drive:4WD, Engine Cylinders:4 | eBay
Mowing is your PRIORITY TASK.
With your slopes and desire to be efficient with your time you probably want a 12' flexible batwing mower, $12,000 new. Rigid dual spindle mowers cost less but primarily for very flat ground where scalping will not be an issue. A 12' mower should cut at least twice as fast as a seven foot wide mower. A mower with SHARP BLADES should cut pasture at 4mph to 5mph; some operate faster.
LINK: Bush Hog(R) Perfomance You Can Count On
LINK: rotary cutter 12&apos; bush hog in Heavy Equipment Attachments | eBay
In order to run a 12' Flex Wing Mower you will need 50-horsepower at the PTO, if not cutting saplings greater than 1-1/2". You will also need a 4-WD tractor for traction.
If you revise your T-B-N profile to include your city and state, someone may inform you of a good used tractor and or 12' mower for sale near you. This happens regularly.
Why not shop? You have time. Keep some cash readily available. You will need a tractor that has serivce within twenty miles. Used tractor prices are lowest when there is snow on the ground.
Tallman Water Pump (A50774)
Tallman Water Pump...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2011 BMW 550i GT Sedan (A50324)
2011 BMW 550i GT...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
