Dealer equipment Info
   / Dealer equipment Info #1
AllDodge
Platinum Member
S, Central, KY
Terramite T5C, Kubota M9540HDC24, F3990, RTV1100, Cat 416C, D3B, 955L
Anyone have access to the dealer data base which can advise what has been done to a tractor?
Looking for info on prior repairs. No names needed nor who did the repair, just what repairs were done over the years.
   / Dealer equipment Info #2
Good luck on finding anything like that.
"Car Fox" for tractors ??????
There are folks on the boating sites that will look up a boat. Can go to about any car dealer and the parts counter will also look things up, its no skin off their nose. They don't give you personal info, just what repairs have been done.
Next time I'm at Kubota, I'll see if they will
   / Dealer equipment Info #4
Did you call your local dealer?
With one of my used tractors, I called the originating dealer based on a sticker they had placed on the tractor (actually several). Simply explained that I bought a used tractor and was wondering if they could provide any service or other info related to the tractor. They obliged without issue.
   / Dealer equipment Info #5
Unfortunately there is no such thing as "TractorFax" the equivalent of "CarFax" for tractors. I think that is one of many things that only happen when the market reaches a critical mass large enough to support such "side industries." The tractor business isn't quite large enough for that plus I'd bet the main tractor manufacturers would not encourage or support it. There are also a few factors inherently different -- like little or no "accident records" or insurance companies with collision records and databases.
Didn't think about it, will give it a try tomorrow
Dealer very helpful with info, there just was not much of it. Said at 184 hours it had a radiator assy installed, and that was it. So guess the other work was done by someone else
Kioti DK 35, 4WD, Quick Attach Loader with Bucket  (A52384)
Kioti DK 35, 4WD...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
BY VALLEY INDUSTRIES 60 R22 823 LOT IDENTIFIER 221 (A53084)
BY VALLEY...
(APPROX 36) 2" X 5" X 21" CHANNEL IRON (A51247)
(APPROX 36) 2" X...
