Deadman
   / Deadman #1
RCannon
Bronze Member
thumb of Michigan
TC33D
Planning on fixing two 8ft gates this spring...have to lift them up to move them.
questions for the experts here.
I plan on using 6X6 treated posts and sinking them at least 50 inches. To avoid sagging again I was thinking I could use a deadman between the posts and was wondering what material to use? Wire cable? another post... say a 4X4?
Does the drainage in the area dictate what I should use?
any thoughts?
   / Deadman #2
If you are running high tensile, you could just run a deadman from the bottom of the next post and put a crank on it. If it sags, give it a wind.
Wood looks better and if you really want to you put up two rails to the next post 6-8 foot away.
We have done that on corners for HT fence, sometimes adding a wire and a crank.
2008 CATERPILLAR 325DL Long Reach (A52384)
2008 CATERPILLAR...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
1262 (A50490)
1262 (A50490)
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
