patrickjs
I'm usually fairly good trouble shooting tractor problems but now I'm stumped. Originally the engine wouldn't turn over after the glow plug light went out, no ignition power. So I got a screw driver and shorted the solenoid to get her started, cold winter emergency. I know you aren't supposed to do that but I had to clear 4' of snow last January. So now I pulled the starter and took it in for repair. The shop said the starter was fine that my ignition switch was weak. He said to either put in a relay between the ignition switch and solenoid or replace the switch. I replaced the ignition switch but now I have no power anywhere when I turn on the key. The battery is good. I replaced all fuses including inline. Replaced the four relays under steering wheel. Still no power. So I put the old ignition switch back in, no power. The battery cables are clean and battery good charge. I don't know what else to try.
