Dead MF 1433v
   / Dead MF 1433v #1
wayne48
Bronze Member
Vermont
MF 1433v
My Massey was choking on gelled fuel. I finally got it running with heat on the fuel bowl and copious amounts of anti- gel additive. Idle was starting to smooth out. So I started to back the tractor out of the barn. Just cleared the doorway when she just died. Tried to restart and now nothing works- glow plug indicator, fuel pump, starter. Turning the ignition to start and nothing happens not even a click! No dash lights, nothing electrical appears to work.
Battery checked with voltmeter- 13.4 volts, all the fuses checked, all good. WTF!
Any ideas, suggestions?
   / Dead MF 1433v
Fixed. Corroded wiring at the battery post connection. That and a weak battery combined to take her down. Cleaned the wiring, reconnected the battery and jumped it. Started right up (of course it was 30 degrees warmer than it was when all this started.) Got a new battery and the Massey is purring again! All is right with the world.
   / Dead MF 1433v #4
You might also want to check out the ground cable/strap.... they can have a very negative effect --both in charging and starting-- if they're flaky. Certain models of MF tractors have had this issue.
2013 FORD F-650 ROUSTABOUT (INOPERABLE) (A52472)
2013 FORD F-650...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
SKID STEER BROOM ATTACHMENT (A52472)
SKID STEER BROOM...
New Long Forks (A53002)
New Long Forks...
2015 FORD F-550 SUPER DUTY (A52472)
2015 FORD F-550...
