dead battery
   / dead battery #1
Boulter
Central Ontario
Kioti DK40SE
Hi:
I went to use my DK40SE last Thursday and found the battery dead. Last used it about 2 months ago, and there have been plenty of two month intervals between usages. I charged the battery and got the job done later in the day.
Any thoughts as to why this might have happened? It is out in the open, so maybe just a short by dirty snow and water.
I won't get back to it until Wednesday at the earliest to see if the problem repeats.
Boulter
   / dead battery #2
I think the first question would be , how old is the battery? I think if you are talking about a battery older than 2 or 3 years old you are asking alot of a battery to sit 2 months with out a battery tender . It could be a bad cell dragging it down . First thing I would do is have the battery checked .
DK40SE
   / dead battery #3
The older a battery gets, the less time it will hold a charge. Not good for a battery to let it sit for extended periods of time. I start my tractor at least once a week just to keep the battery fully charged.
   / dead battery #5
I had several dead battery occasions with my DK45S until I changed the positive battery clamp. Original was so thin it would stretch, loosen, oxidize, & not charge. MikeD74T
   / dead battery #6
The real question is why oh why would you let your poor tractor sit for two months without use?! :D
   / dead battery #7
My tractor(3054xs TLB) often sits for a couple months not being used and I've yet to have a battery problem; original battery and unit purchased April 2005 :thumbsup: It does rest indoors in my unheated garage, however. Now, I've probably jinxed myself :(
   / dead battery #8
:laughing::laughing::laughing:
YEP!!!.. You're buying a battery NOW!!!..
   / dead battery #9
Winter is the killer of marginal batteries. As they age, they loose their ability to hold a charge. Every year, it's a little bit, until it just can't make it through the cold temps. I've replaced two batteries so far this spring, and had to jump the two batteries on my dozer. I had one of the coldest winters on record here, and my equipment sits all winter long.
Eddie
   / dead battery #10
if i were to leave mine sit that long in colder climates (as i do with my jet ski batteries, trailer battery, lawnmore battery) i put them on my 1.5 amp trickle chargers. You can get the Stanley 1.5 volt automatic trickle charger for $19.00 at Lowes. they work great, but arnt waterproof. i guess you could place it under the hood???
my equipment all resided under a shelter of some kind. i wont let my money sit out and rust (im weird like that).
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
Case 585E- INOPERABLE/PARTS ONLY - NO ENGINE (A52128)
Case 585E-...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2023 KOMATSU WA480-8 LOADER (A51242)
2023 KOMATSU...
