Comparison Dead 1300 D
   / Dead 1300 D #1
JPARR
Northwest
Yanmar 1300d
My poor little 1300 D spun a cranckshaft. Very sad day! Been looking for a motor or?? I am wondering if any other solutions exist.....Say. Will another model engine fit in the tractor? Will the FEL and parts fit another size tractor? If I found a 2wd can the 4wd parts from mine be used to convert it? Any ideas out there? Thanks
   / Dead 1300 D #2
The engines in these little tractors are designed to be rebuildable. The bearings are readily available. What about just fixing the one you've got? The parts will probably be adaptable to some other machines. A YM155 will be easy, since they are basically the same tractor. Trying to match it up to a bigger tractor may be more tricky.
   / Dead 1300 D #3
Like 284 said, I think rebuilding yours is the most direct approach.
You might also research if Yanmar built a boat engine using your block of the same cc and in the same era, or even an engine for a semitrailer refrigeration unit. (These both were the case for YM2000). Those might be cheaper sources for a salvage block.
   / Dead 1300 D
Thanks guys,
Both good ideas. I'll look into them. Let you know what I find out.
   / Dead 1300 D #5
I think Bruce1966 is a buyer/seller of used Japanese engines maybe he will see this or you could pm him he is around here usually.
   / Dead 1300 D #6
I'm in the same boat..need new engine for my Yanmar 1300. anything you find please let me know. Thank you in advance.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 10...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2239 (A51244)
2239 (A51244)
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
