De-Thatcher clenup?
   / De-Thatcher clenup? #1
producer
If I use a de-thathcer behind my tracktor what would be the best way to cleanup the thatch? I was thinking of using either a bagger or a lawn sweeper. I would think between the two, the bagger would work better. Does anyone have any experiance with this? I really do not want to have to rake.
   / De-Thatcher clenup? #2
When I was in the lawn business I used a rake and a big sheet. Rake into windrows, and then lay the sheet flat -- rake onto the sheet, grab the 4 corners and walk it over to the trailer like Santa Claus to dump it.
After I was complete, I used my mower (with bagger) to finish the job.
   / De-Thatcher clenup? #3
I used my mower bagger. I was amazed at how much grass the dethatcher removed, while still keeping the grass looking full. I hadn't dethatched since I bought the place 5 years ago, so a lot had built up. In the past when I mowed, I usually filled up the bagger twice if the grass got long. When I mowed up the thatch, the bagger filled up 18 times! However, with the grass thinned out now, it only fills up once when I mow.
   / De-Thatcher clenup? #4
I de-thatch and mulch at the same time
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2017 Lincoln MKC SUV (A53117)
2017 Lincoln MKC...
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2013 PETERBILT 388 DAYCAB BOBTAIL VACUUM TRUCK (A53843)
2013 PETERBILT 388...
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
