David Sharp
   / David Sharp #1
David Sharp
cub cadet 2185
I have a cub cadet 2185.while mowing my PTO quit working.it had been intermitting foe a while but now wont keep engaged.it has only 229 hours on it.I can't believe it has gone bad.please tell me how I can hot wire it to see if it is really bad.Thank you.
   / David Sharp #2
check your owner's manual to see if that machine has an adjustable PTO clutch. If so, adjust and retest. If not, sit in seat, turn ign sw to run, (Do NOT start engine), park brake engaged, turn on PTO switch.
Should hear a sharp click from PTO clutch . If not, PTO is not getting 12volts. Check for bad PTO switch or failed safety switches. If so, have battery LOAD tested by qualified shop, clean elect terminals , retest.
If you are familiar with VOM's or test lights, you can check circuitry by unplugging connector close to PTO... then check coil for correct ohm values (see mfgr's published specs) and supply circuit for correct power.
Also, do a simple check that deck belt tension is correct and that all related idler pulleys, mower deck spindles, etc., are turning freely.
   / David Sharp
I checked the ohm's and it is 2.27ohms.how do I find the correct measurement?
   / David Sharp #5
once you can determine the clutch's mfgr, go to their website - you should be able to find specs on coil resistance.
BTW, 2.27 ohms sounds in the ball park... I would look elsewhwere for probs (mho)...
PS: just saw where OM has provided you specifics - good luck.
Kubota RTV-X900 Utility Cart (A50322)
Kubota RTV-X900...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
2023 John Deere 8R410 MFWD Tractor (A52128)
2023 John Deere...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52128)
NEW 2024 LOAD...
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
